1968 cutlass power antenna ecutscheon and interior headliner side moldings
Old Aug 3, 2014 | 06:42 AM
jstrits's Avatar
A friend is looking for a very nice power antenna ecutscheon that sits on top of the quarter panel. Its the bottom piece that sits oon top of the gasket nd then the top piece which is threaded and has two notches that is used to tighten it down. His are pitted and flaking. Also good straight dent free anodized headliner strips that run from the visors to sail panels.
Old Aug 3, 2014 | 08:13 AM
66400's Avatar
Power antenna bezel works for 68 and 69. If I remember correctly Convert and 4drs bezels are not the same as 2dr closed body styles.
Henry
Old Aug 3, 2014 | 12:19 PM
jstrits's Avatar
Not sure about body styles. being its top of the quarter near the trunk I wonder how different that area is between the models. Either way I need the two pieces.
Old Aug 3, 2014 | 03:11 PM
allyolds68's Avatar
2 door has a "V" on the bottom and straddles the peak break. 4 door/vert one is angled with a single break which mirrors the panel. I used a big car one for my convertible. The angle seemed slightly different than the 4 door/convertible but you can't tell the difference once it was installed. Henry could probably tell you if they are definitely different
edit:
I just checked Ames and they reproduce the part for a 68-69 GTO but there isn't a picture of it. You might want to call them
Old Aug 3, 2014 | 04:33 PM
jstrits's Avatar
This is what is needed. The larger base piece has a #400017 on the underside.antenna.jpgantenna2.jpg
Old Aug 5, 2014 | 03:08 AM
Yellowstatue's Avatar
Those pieces are for a closed coupe.
Old Aug 10, 2014 | 06:54 PM
jstrits's Avatar
Don't need moldings but still need the antenna pieces
Old Aug 21, 2014 | 08:46 AM
old442's Avatar
If you ever find one, I would like to purchase or borrow your old pieces for a guide to have some machined out of aluminum. No one is reproducing these and they are very hard to find . Thanks, Charles
Old Aug 21, 2014 | 09:02 AM
Octania's Avatar
I agree that we need someone to take on the project of having these made in clear anodized AL or perhaps SS.
Old Aug 21, 2014 | 02:40 PM
442mark's Avatar
X3 on someone reproducing these. The power antennas aren't too tough to find since they were used on many GM cars of the era, but those chrome spacers are Olds specific and pretty scarce. #400017 for hardtop & post coupe, #400018 for convertible & 4 door, 1968-69
Old Aug 21, 2014 | 02:59 PM
Octania's Avatar
PN's added to database
I will toss in here also
400021 = GASKET, antenna mount to rear fender
1968 A-body convertible and 4dr
Impossible to find anymore.
Old Aug 21, 2014 | 04:37 PM
allyolds68's Avatar
Big car ones are very close. That's what I used.
curtis mayfield
Feb 21, 2023 07:13 AM
72455442RA
Aug 14, 2015 07:02 PM
197064buickspec
Aug 4, 2014 12:26 PM
197064buickspec
Aug 19, 2013 09:23 PM
