TH400 Kickdown switch plug needed
Old Apr 21, 2014 | 09:57 AM
Uncle Hulka's Avatar
Ancient Olds Lover
I'm converting from a TH350 to a TH400 and I am in need of the plug, boot and as much of the wire as possible, that goes onto the transmission kick-down solenoid.
If anyone can help me out I would appreciate it. If they're in CT, I can pick up.
Thanks very much!
Uncle Hulka
Old Apr 21, 2014 | 11:51 AM
droptopron's Avatar
delete
I assume its for the full sizer pictured. In an A body its part of the harness but not used. Maybe your's is the same way?
Old Apr 21, 2014 | 12:53 PM
Ancient Olds Lover
Sorry, I should have offered more details in my request.
The trans is out of a '69 Delta and is going into a '69 Cutlass. As outlined in the 1969 PIM, I found the connector that plugs onto the kick-down switch taped back onto its harness. The PIM says that if the car in question was made with a TH350, the connector that would normally be used to plug onto the TH400's kick-down solenoid is to be cut off. Evidently whoever's job it was to cut that connector off, cut the entire wire off right at the backside of the fuse panel on the firewall!
Long story short, I am in need of the connector plug, its boot and as much of its wire lead as possible.
Old Apr 21, 2014 | 01:22 PM
70cutty's Avatar
Beer Connoisseur
There is this one on Ebay
http://www.ebay.com/itm/68-69-TH400-...891d26&vxp=mtr
Old Apr 21, 2014 | 05:45 PM
Ancient Olds Lover
Hmmnnn.....didn't realize they made a repo harness. A used one would have been fine, but this looks like a great solution.
Many thanks!
Old Apr 23, 2014 | 04:34 AM
Ancient Olds Lover
Originally Posted by 70cutty
Thought you should know that I think your suggestion will be my solution. I pulled the trigger and bought that harness. I'll let you know how that works out.
Thanks very much for your suggestion and link. I appreciate it more than you might think!
Old Apr 23, 2014 | 05:00 AM
70cutty's Avatar
Beer Connoisseur
Glad I could help. I hope it works for you.
The Bug Man
Mar 27, 2015 01:59 PM
mmurphy77
Jul 2, 2014 12:03 PM
Olds luvr
Feb 26, 2014 05:29 PM
Pryora
Aug 6, 2012 05:59 AM
AZ455
Nov 27, 2011 08:35 AM
