Need 59+64 parts.
Old Apr 15, 2014 | 08:31 AM
electra483's Avatar
Need 59+64 parts.
Old Apr 16, 2014 | 12:49 PM
mpolds's Avatar
1959 & 1964 Olds Parts
You're supposed to have all the nice salvage yards out there in Arizona!!!!
And you need the rest of the world !!!! Well, hopefully, this C.O. site comes
through for you -- this is the spot!!!!!!!!!!!
I have plenty of mechanical parts for those cars --- Brakes, front End, Motor Mounts, Bearings, Seals, Fuel Pumps, Ignition, and Electrical, and so forth..
For cosmetics and pieces of cars; we sure all do miss Rex Hall, Soldier; Kansas with acres and acres of OLD OLDSMOBILES!!!!!!!!!!!!!!
If you ever need me -- Craig -- 516 - 485 - 1935... New York....
Old Apr 18, 2014 | 03:19 PM
electra483's Avatar
Old Apr 19, 2014 | 01:10 PM
mpolds's Avatar
I returned your call the other day....
I did return your second call but I didn't hear back from you....
happen to be in the library, so I thought I'd just say "hi" here....
Running around like mad here on Easter weekend -- getting set up
to leave for Carlisle, Pa. -- for the big show -- on Monday....
Have a Happy Easter -- and if you need me, call, I can probably call
you back one evening (my time) while I am at Carlisle....
C'mon C.O. guys -- help Paul with his needs!!!!!!!!!!!!!
Where are you to come to the rescue?!?!?!?!?!?!?
----- Craig
Old Apr 19, 2014 | 08:13 PM
electra483's Avatar
Old May 28, 2014 | 06:40 PM
electra483's Avatar
Old May 28, 2014 | 06:55 PM
59-59-59's Avatar
Ill send you a pic of a '62 manifold- I forgot if it was off a Starfire. PM me your email
Old May 28, 2014 | 07:30 PM
deaddds's Avatar
Hi Paul. I have the lenses and air cleaner if you want photos let me know. Pat in IL.
Old May 28, 2014 | 07:41 PM
electra483's Avatar
Old May 28, 2014 | 08:26 PM
deaddds's Avatar
I'm pretty sure the 63/4 are slightly different than 61/2 in the passages but look like they would line up to the same bolt holes. I need to talk to Everett Horton, he probably knows for sure. I have a 61 starfire motor complete and the stamp code on the manifold is the same for 61/2 but I think you want a dual manifold and I don't know if a dual exhaust was put on 61/2s.
Old May 29, 2014 | 07:01 AM
Oldskeeper's Avatar
Hi Pat, the 63/64 dual exhaust manifold will fit a 62 as I added it to the 62 wagon, it should fit the 61 Starfire. The dual exhaust manifold was only available for the 63/64 394 engine, the earlier manifold was the single exhaust system manifold and they just rerouted the piping for dual.
Steve
Old May 29, 2014 | 07:30 AM
electra483's Avatar
Old May 29, 2014 | 02:51 PM
Oldskeeper's Avatar
Hi Paul, good to see that Vinny is still in the game!
OK to be correct for your 62 88 all you need to do is reroute the drivers side exhaust pipe down and back, you will need the blocker plate for the front of the passenger side manifold.
Now if you want the car to breath easier and have less problems with the tight bends required for the drivers side swap the exhaust manifold with the 63/64 dual exhaust one.
I know it will fit in the space provided because I added it to my 62 super 88 wagon.
Hope this clears things up for you.
The part number I'll have to look up for you but the manifold is only for 2 years and does not fit any other engine so if I remember correctly the part number is the same.
Steve
OK Paul I just looked it up 63/64 dual exhaust manifold 587793
1pc. 587793 1963/32-35-36-38-39 with dual exhaust-left
1pc. 587793 1964/34-35-36-38-39- with dual exhaust-left-not used with st on 34/-57/
this is how it reads in my parts book
the 61/62 exhaust manifold are 579278-right
579279-left
Steve
Old May 29, 2014 | 04:46 PM
electra483's Avatar
Old May 29, 2014 | 06:26 PM
deaddds's Avatar
Paul, shoot me your email again so I can get you these photos. dead@mchsi.com
Old May 29, 2014 | 07:07 PM
electra483's Avatar
Old May 30, 2014 | 03:27 PM
Oldskeeper's Avatar
You are welcome any time I can be of service just call.
Vinny hasn't called about the Aluminum panels, are the ones on the car good enough for you?
I added the dual exhaust manifold to my 63 98 convertable and a new system with resonators and it sounds great and moves down the road really quick.
You will need to add some pictures of the Starfire for us to admire!
I have an offenhauser 3x2 manifold for a 59 394 that I'm making the shim plates and installing it on my 62 starfire wagon.Are you going to the Nats in Cinncy this year?
Talk later
Steve
Old May 31, 2014 | 07:45 AM
electra483's Avatar
davek1661
Apr 12, 2024 12:29 PM
oldspackrat
Jun 3, 2023 08:50 AM
pick
Oct 20, 2012 05:25 PM
Vistabrat72
Apr 23, 2012 06:16 PM
Art Vandelay
Mar 21, 2009 09:04 AM
