need some sbo 350 parts
Old Mar 10, 2014 | 02:14 PM
billmerbach's Avatar
major noob
Hey guys I owe you so I need to buy some things from you..
  • carb nothing fancy but needa to be runnable
  • oil pum and oil screen
  • intake bolts someone lost mine >
  • water pump
  • alternator
Am I missing anything if I am I'll find out like
Old Mar 10, 2014 | 06:20 PM
major noob
It may help if I list that the engine is from a 1970 cutlass supreme
Old Mar 12, 2014 | 03:18 AM
major noob
Anyone?
Old Mar 12, 2014 | 06:30 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have oil pump, alternator, water pump and bolts. I have an old qjet carburetor, but not sure if it runs or not.
2 questions:
1. internally or externally regulated alternator?
2. what letters are stamped on your crank and water pump and power steering pulleys?
We need that information to find you the right stuff.
Old Mar 12, 2014 | 06:45 AM
major noob
Not sure about regulation I'd assume internal and IFK about the crank # I got a reman
Old Mar 12, 2014 | 06:49 AM
He needs an internally regulated alternator.
And not the number on the crank, Bill, the number on the crank pulley.
Old Mar 12, 2014 | 06:51 AM
if it's for your 77 it'll be internal and it'll have a 6" water pump unless you messed it all up changing things lol.
Old Mar 12, 2014 | 06:53 AM
major noob
I don't thinknibmessed up anything its a 70 350 going in my omega
Old Mar 12, 2014 | 07:00 AM
ok good. the car cant tell the difference in blocks. use all of the 77 brackets and pulleys that came with your car. I have a water and oil pump, and intake bolts here for you. my alternator wont work for you.
Old Mar 12, 2014 | 07:03 AM
major noob
I have all brackets I think
Old Mar 12, 2014 | 07:11 AM
No, no, no. He's taking a Buick V6 out of the car, and putting a '70 SBO in.
He has no original X-body brackets.
He's got to experiment and see what fits and what doesn't.
Odds are that the '72 or '73-on bracket set used with both A- and B-bodies will work, but I'm not sure whether anyone who doesn't have a 260 Ωmega knows.
Old Mar 12, 2014 | 07:56 AM
major noob
also a dizzy I need one I can plug my tach into is that hei?
Old Mar 12, 2014 | 08:25 AM
Your tach can be used on any distributor.
Old Mar 12, 2014 | 09:52 AM
major noob
It'll plug right in? I mean without having to splice anywires ik I can hook it up to any dizzy but which one will be a put in and go kinda thing? Is that a clearer question? I can't really explain what I mean lol
Old Mar 12, 2014 | 10:05 AM
You haven't done much electrical work yet, have you, Grasshopper?
You need to get comfortable with wiring, soldering, and troubleshooting, because if you're going to be driving 40 year old cars, you're going to be doing plenty of it.
The low-voltage electrical systems on cars are susceptible to small amounts of corrosion causing enough resistance to make things not work, so all connections should always be soldered to eliminate this possibility. You need to keep an eye out for a decent soldering iron. For most of the work you would be doing on your car, a Weller pistol-type inductive heated unit is probably the best.
They look like this:
You can usually find them at yard sales and flea markets for about $5, often unused, and sometimes in cases with solder, flux, and spare tips.
Soldering is quick and easy, and will need to be done whenever connecting any tachometer in any car, if you're doing it correctly, no matter what kind of distributor it has in it.
Any tachometer made in the last forty years will have four wires that need to be connected: One to a +12v source that is on when the ignition is on, and off at other times, one to the dash light circuit, one to ground, and one as a sensor, to the ignition system.
The only difference between points and HEI when connecting a tach is that on a points system, you solder a ring terminal on the sensor wire and connect it to the (-) terminal post on the coil, while on and HEI system, you solder a ¼" female spade connector on the sensor wire and plug it into the "TACH" terminal on the HEI.
Does that answer your question?
Old Mar 12, 2014 | 10:14 AM
I use crimp style PDIG terminals, with a ratcheting crimper.
Old Mar 12, 2014 | 10:23 AM
Do they squeal when you pinch 'em?
Old Mar 12, 2014 | 10:28 AM
I do.
Old Mar 12, 2014 | 10:40 AM
major noob
Oh I can wire I just don't want to if I don't need too lol
Old Mar 12, 2014 | 01:33 PM
major noob
If you have anything let me know I can wire tho lol I'm waiting to buy some stuff till I see what I can buy from you guys here
Old Mar 13, 2014 | 06:47 AM
major noob
Chicago pm me with what you have
Old Mar 15, 2014 | 04:43 PM
major noob
Bump
Old Mar 22, 2014 | 04:09 PM
major noob
  • water pump
  • alternator
Ok hei is taken car of so is carb and hopefully oil pump still need intake bolts a harmonic balancer an alternator and I believe that's it
Old Mar 22, 2014 | 04:33 PM
dnmfranco's Avatar
have balancer
Old Mar 22, 2014 | 04:34 PM
major noob
Email me a pic and price please to billmerbach@gmail.com
Old Mar 22, 2014 | 05:36 PM
stan 65 cutlass's Avatar
you can hook your tach to the points side of the coil, bolt it right on
Old Mar 22, 2014 | 05:38 PM
major noob
Ik I realized that lol my v6 had hei
Old Mar 22, 2014 | 05:56 PM
Octania's Avatar
Hate to hijack, but, can you post a link to look into these?
Old Mar 22, 2014 | 05:59 PM
major noob
Don't worry about it octania it bumps my post
Old Mar 23, 2014 | 02:24 PM
major noob
Add hei wires to that list lol
Old Mar 23, 2014 | 03:00 PM
  #31
copper128's Avatar
Lt. Buzzkill (ret.)
I also have an original V6 Omega SX with a gauge pkg dash. Does anyone know if the factory tach is switchable for # of cylinders? I've never had it out of the car, so haven't seen the back of it. I'd like to have it functional with the V8 swap if possible.
Old Mar 23, 2014 | 04:14 PM
  #32
major noob
Correction hei is not taken care of smitty didn't have one lol so I need one of those now
marxjunk
Sep 24, 2014 03:20 AM
71403
Sep 4, 2011 12:08 AM
f-85
Aug 15, 2010 11:15 AM
crazy'boutOlds
Jul 24, 2009 01:37 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
