WTB 4bbl carburetor
Old Nov 23, 2013 | 05:49 PM
dantecl's Avatar
WTB 4bbl carburetor
Hey folks,
Looking for a 4bbl carb for my '72 delta 88 with a 455. The current one needs to go. Summit has remanufactured ones for a couple hundy but I'd rather not spend that much right now. Anyone got a spare laying around?
Dante
Old Nov 23, 2013 | 06:58 PM
Why does it need to go?
Old Nov 23, 2013 | 07:40 PM
dantecl's Avatar
Because it'll need too much work to rebuild. Also, the carb number is 17057553, which I can't find reliable info that it was used in '72 cars. Seems like it was replaced at some point.
Old Nov 23, 2013 | 07:49 PM
Seems to me rebuilding a carburetor always takes the same amount of work: Disassemble, Clean, Reassemble, Adjust.
As for the number, it looks like it was used on 1977 California, air conditioned Olds smallblocks.
Since you're using it on a '72 455, which is larger and did not have EGR, it's probably running lean compared to the original.
Is your engine modified or original, as this may affect your choice of carburetors.
dantecl's Avatar
http://quadrajetparts.com/decode-you...retor-t-5.html
Is this page accurate? If so, man, is this carb wrong...
Old Nov 23, 2013 | 07:51 PM
dantecl's Avatar
My engine is bone stock. Auto transmission. Right now the thing is not running and it blows fuel up the top. If I'm gonna spend time rebuilding it, might as well get a carb that's correct for my car.
Old Nov 23, 2013 | 08:00 PM
I would agree. When you get it running, it may run better with a pre-'73 carb. (though with all of the variables involved, including general engine wear, who knows?).
Welcome to ClassicOlds.
Old Nov 23, 2013 | 08:10 PM
oldstata's Avatar
Justin
I think I have a 73 Pontiac carb not ready to run it's been sitting many years
Old Nov 23, 2013 | 08:14 PM
dantecl's Avatar
Would it fit an olds 455? I'm not knowledgeable when it comes to interchangeability for these parts.
Old Nov 23, 2013 | 08:23 PM
Any QuadraJet will bolt on (all except for Chebby and early '66 Olds will have the fuel inlet in the same place), but jetting and other specs will be different for big and small blocks, as well as for different emission configurations, and, to a lesser extent, different Divisions.
Old Nov 23, 2013 | 08:27 PM
dantecl's Avatar
Good to know. I'm not particularly interested in keeping it "CA standard" as it's smog-free, but I'd like something that'll make my 455 run good. Ideally I'd like a working carb, not necessarily new, but a rebuildable carb that won't require parts outside the regular kits would work too.
Old Nov 23, 2013 | 08:38 PM
oldstata's Avatar
Justin
I can pull numbers tomorrow, but you might be able to get a used edlebrock or holly and rebuild it. edlebrock is super easy, but seems like 50% rather go with holly
Old Nov 23, 2013 | 10:02 PM
The only problem with changing to a Holley or an Edelbrock is it won't directly bolt to a stock manifold, they are square bore. An adapter would be required. Imho you probably ought to stick with the Rochester.
Old Nov 23, 2013 | 10:07 PM
oldstata's Avatar
Justin
Can you explain this a bit more I have a edee on my stock 330 with no spacer ?
Old Nov 23, 2013 | 10:15 PM
Your year is different and yours came with a squarebore carb. His is a spreadbore and will require an adapter. Take a look at the manifold on your 455 and you'll see.
Old Nov 24, 2013 | 02:16 AM
nsnarsk65cutlass's Avatar
Thats right.the edelbrock carb is a carter afb it will bolt up to the q-jet intake but the throttle plates will not open.The pre 66 330 used the 4gc aka 4 jet that is square bore and the afb or edelbrock will work.I'd stick with the q-jet.
Old Nov 24, 2013 | 01:50 PM
dantecl's Avatar
Yeah I'm sticking with Qjets. It's a fine carburetor when properly rebuilt, and doesn't require me to do any voodoo with intake manifold and/or fuel line.
Old Nov 24, 2013 | 01:56 PM
69ishHoliday's Avatar
You might save yourself a step in the process by checking with a restoration source and see if they have one to sell. People on this site speak very highly of Sparky's and I had a great restoration done for me by Bob Stone of Classic Carbs.
Old Nov 24, 2013 | 03:50 PM
Ask John (2blu442). He's got everything.
Old Nov 24, 2013 | 03:53 PM
John is great to deal with BTW.
Old Nov 24, 2013 | 04:23 PM
oldstata's Avatar
Justin
X3 great guy fast shipping
Old Nov 24, 2013 | 04:30 PM
billmerbach's Avatar
major noob
How much might you be willing to pay I may get a few in a some boxes of parts I should be getting in the /ext 2_4 weeks
oldstata's Avatar
Justin
Here is the numbers on the one I have
If I recall its 73 Pontiac
Old Nov 24, 2013 | 08:37 PM
dantecl's Avatar
17054779 = post 75 carburetor. If those are the numbers, in fact.
Old Nov 24, 2013 | 08:39 PM
dantecl's Avatar
Well I lost an auction for a '71 qjet tonight (it went for $107 shipped) so I'll contact 2blu442 and call up Sparky in the morning to see if he got something as well. Looks like I ain't getting out of this bind on the cheap.
Old Nov 24, 2013 | 08:43 PM
lemoldsnut's Avatar
You should be rebuilding any carb that has sat any time at all. To correctly do that you need to epoxy the plugs and possibly rebush the throttle shaft so it will not leak due to wear.
Qjets are great carbs when set up correctly
Old Nov 24, 2013 | 10:27 PM
orange442's Avatar
I have 2 complete 72 455 motors, one out of an 88 and other out of a 98 and if I remember correctly, both have the same number carb, 7042251, I will have to check.
Old Nov 24, 2013 | 10:53 PM
dantecl's Avatar
Cool, let me know if you're willing to part with a carb.
Old Nov 25, 2013 | 04:12 AM
major noob
I have a reman in a box all things are there needs to be rebuilt but nothings stuck my dads asking asking 80 plus shipping is that resonable
Old Nov 25, 2013 | 04:31 AM
Originally Posted by lemoldsnut
To correctly do that you need to epoxy the plugs...
Only the early carbs ('66 and maybe some '67} had the well plug leakage problem, and epoxy is not a permanent fix for these - new spun-in plugs is.
66olds4dr
Jun 8, 2015 03:45 PM
thegreat'71olds442
May 11, 2015 12:00 AM
Rocket Richard
Feb 14, 2011 07:46 AM
yeahbuddy
Jun 1, 2010 05:38 AM
