65 trans yoke
Old Sep 28, 2013 | 07:54 AM
lilhow's Avatar
65 trans yoke
Hi all
I put a th350 in my 65 f85 and noticed yoke had bin repaired with a disk grinder. Drive shaft has wrecker paint "68 buick skylark". So looking for yoke or complete drive shaft if close to Kitchener On Canada. Also a tranny dipstick tube. After market one fits like $#(t.
Thanks Jeff
Old Sep 28, 2013 | 08:16 AM
ROCKETMAN269V's Avatar
Wink 65 trans yoke
You may want to change the title of your post to "T-350 yoke". They didn't come out with the 350 trans until '69. I'm assuming that you have the short extension housing on your trans. If you can't find anything closer, I have them down here in sunny south Florida. Thanks, Bob.
Old Sep 28, 2013 | 10:06 AM
lilhow's Avatar
The trans is out of a 69 buick but I use my old drive shaft which is written on it is 68 buick it all fits fine. Grinder marks where seal sits not good very abrasive. I also changed gears to 323 and now that its revving higher (3200) on highway I'm having vibration issues. May have to order one from you if I can't find one closer. Thanks for info.
Old Sep 28, 2013 | 05:52 PM
ferndaleflyer's Avatar
How many different yokes did they make? I was under the impression that the 2 spd one also fit a T-350. ATI lists the power glide and T-350 as using the same yoke. Not sure about the early BOP 2 speeds being the same. I have a van full of driveshafts with yokes up in Baltimore.
Old Sep 28, 2013 | 06:25 PM
oldstata's Avatar
Justin
Honestdave has parted a few 65 located in Canada not sure what part but might be worth checking with him
Old Oct 1, 2013 | 03:33 PM
lilhow's Avatar
Hey, thanks for the reply's but I filled the divot in the yoke with mig and used angle grinders and got it pretty good (we'll see) and going to send out for balancing. Also getting flex tube.
Thanks again Jeff
Old Oct 2, 2013 | 05:54 AM
unless you polished to mirror finish it will eat the rear trans seal quick......
Oldsmaniac
Jun 23, 2014 06:32 AM
jojo66
Apr 29, 2008 12:22 PM
jeffs 89 cutlass salon
Oct 19, 2007 08:42 AM
mcutlass1969
Jan 3, 2007 10:29 PM
