69 Cutlass parts NEEDED
Fyi
This will only work if you run the stock size tire. If you have changed tire size then you will need to change either the drive gear or the driven gear or both.
Check here for speedo gears of all shapes & sizes. Also has a calculator to figure out what you need based on tire size & gearing.
http://www.transmissioncenter.org/GM...eter_Gears.htm
HotRodRacer
Feb 8, 2012 10:25 AM
oldsdelta67
Jun 10, 2009 12:47 PM
