Need a few parts for 72 Cutty
Looking for a dual crossmember for a 400 trans that will fit my 72 W29, and a pair 455 frame pads in good shape. Pm or email me at Kinoyeahboy@live.com
Gracias,
Kino
Gracias,
Kino
All crossmembers for 1972's have the double humps for dual exhaust. It's also the same crossmember for any of the transmission options. So if you have a crossmember from say a TH350 it will work fine on a TH400 or muncie 4 speed. There are different bolt holes in the frame rails so you can adjust it for whatever length of transmission you want to install, as long as it was a factory option that year. If you put in a late model 6 speed you may need to drill some new hole to get the correct location.
John
John
I did not know that 72's all used dual hump cross-members. Just when I thought I figured out ever piece of info about Olds domething else comes from behind the bushes. Thanks John.
For information I have two members that have crossmembers. I will buy from one or the other based on who pm'd first and follow-through on photographs.
I was just going by the Fusick book. I didn't check eBay. I Just looked and i have a nice original set already painted black. With those on eBay being less i will do $45 shipped. I will send pics tonight.
I no longer need engine frame motor pads. Payment sent.Thanks Eric!
Hood hinges for 68-72 Cutlass are the next item on the list.
Kino
Kino
Let me make my self clear. Was looking for a pair of 68 hood hinges, but located them. Now I need a pair for a 72. I'm aware the 68 accommodates 5 bolts and doesn't reach as high as 69-72. So do you have any for a 72 or did you have any for the years specified?
Anyone have a 7 quart oil pan, matching set of pulleys, engine brackets (don't need a/c brackets) prefer one that came from short water pump application. Also trying to get a line on a 3000 stall convertor for down the road at the TC is not needed right now.
I have a Milodon 7-quart pan in like new condition. E-mail for pics, etc: drolds1@bellsouth.net. Thanks, Bob.
Melling
Kino, I have a new Melling M-22F-HV, which has provision for the bolt-on pickup; however, the pickup that is with it is a press in one. These are both new, still in the plastic and in their original boxes. I could ship them with the pan. Bob.
Kidcutty
Suspension & Handling
Mar 5, 2010 08:50 AM
