70-72 rally pack & NOS control arm bushings wanted
Old Jul 26, 2012 | 09:28 AM
jensenracing77's Avatar
I would like to find a 70-72 rally pack. must be an OEM set that works other than the clock. not sure what they are going for right now but i also have parts i could trade.
Also looking for 2 NOS control arm bushings for a rear end. who made them for GM? is there other old stock that i could use that are made from the same manufacturer?
Old Jul 26, 2012 | 09:48 AM
507OLDS's Avatar
I have NOS bushings for the front.You can get OEM bushings for the rear,at most parts stores.Same fit & appearance.
Old Jul 26, 2012 | 12:15 PM
i don't really need to be so picky on the control arm bushings. i have a set of old stock TRWs that look the same also. i will just use those.
Old Aug 1, 2012 | 09:17 AM
Run to Rund's Avatar
Olds used 388266 stiffer rubber bushings in the upper control arms and rear housing of 60s 442s. Later this number was filled with regular soft bushings. Lakewood also made stiff bushings back in the 1970s.
costpenn
Dec 28, 2013 08:39 AM
bigwillystyle
Dec 21, 2009 10:05 AM
therobski
Oct 24, 2009 01:54 PM
olds1968
Jun 10, 2009 12:41 PM
tiparosa
Feb 26, 2007 10:43 PM
