a/c hose 73 olds 98
Old May 16, 2011 | 01:38 PM
raidermaniac's Avatar
a/c hose 73 olds 98
anyone have or know where i can get an a/c hose for a 73 olsmobile 98? it's the hose that goes from the compressor to radiator,any help appreciated.
Old May 16, 2011 | 04:27 PM
rocketraider's Avatar
Oldsdruid
A good A/C or hydraulic hose shop should be able to use your original fittings and make a new one if you can't find one pre-made.
Old May 16, 2011 | 05:06 PM
69442C's Avatar
.............. it's the hose that goes from the compressor to radiator.......[/quote]
I assume you meant to say its the hose that goes from the compressor to the condenser as the AC lines wouldn't go to the radiator. The condenser sits in front of the radiator. Just wanted to make sure you had the correct terms while doing your search. If you don't find anything or anyone local, try Classic Auto Air in Tampa FL. Send them your old one and they will duplicate it. Better yet, send all of them if you can swing it and get all of them duplicated so another one doesn't fail in the near future. You will want to seal the system as best as you can while the hoses are off to keep it clean and dry. If the receiver/drier is original, now would be a good time to replace it too. It's the thing up with the condenser that looks like a metal bottle. I believe it can be rebuilt so check with CAA if you decide to use them.
Sampson
Mar 24, 2015 09:33 AM
84oldsDelta88
Jan 3, 2012 02:57 AM
kenny
Mar 26, 2011 11:12 PM
Del70
Mar 1, 2011 03:46 AM
KQQLCAT
Jun 4, 2009 07:23 AM
