1955 olds 98 trunk emblem
I doubt you will ever find the rocker moldings. My understanding is they were optional and nobody repops them. The trunk emblem should not be a big problem. It just may take a little patience.
You will probably find it. One of the things you will find is that it takes time on these old Oldsmobiles. If it were a Chevy you could just call Danchuck or somebody like that and have the thing in a day or two. As much as a lot of people hate ebay, it is your friend on these cars. The batwing aircleaners come up pretty often and usually go for about $125. They are very collectible since the retro hot rodders use them. Cadillac used the same air cleaner so you might try searching under Cadillac. Try this link.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
All parts are not easy to find as you will discover. If Fusick does not have it, more than likely nobody else does. Some parts will take patience as I mentioned in my previous post. Your trunk emblem may be one of those parts.
dz442
May 23, 2015 02:19 PM
oldzy
Jan 21, 2013 04:02 PM
