76 Cutlass Door Pull Trim cap insert needed
Hey there,
I'm looking for 1 of 2 of these door pull trim inserts. Pictures attached.
It's the snap in insert that goes in the plastic door pull cap. The one on the left has the insert I need. Any idea if anyone makes this anymore or would any of you have a parts car with them?
Thanks,
Chris
Thanks,
Chris
Hey there,
Thanks,
Chris
Thanks,
Chris
I believe these caps are the same as the ones used on the earlier years Cutlass Supremes. If so they are made by Fusicks. I would suggest you also check with Oldsguy (Dan) and 442much (Ken). They both know a lot about 76 Olds. Here is the link. http://www.fusick.com/catfile/Catalo...Layout%203.pdf Check page 67. They're pricey new. You can also get them pretty cheap on ebay. You might also check with John in Medford (2blu442) he has a ton of stuff that probably includes what you're looking for.
coconv
Oct 14, 2012 01:32 PM
