I have been looking without success for the proper rear exhaust hanger for my 1970 Delta 88 350. Can't find it when searching by specific model or generic B-Body. Hoping someone can aim me in the right direction. Sorry for the cobwebs in the photo!
Thanks for replying. I have it temporarily wired in place and prefer not to remove it until I have a replacement candidate in hand. Here is another view of it. It looks to hang over the top of the frame rail. There appears to be a tab that inserts into the frame in the area the hanger is bolted on. Hope this helps a bit.
The A-body hangers do not work and the hangers for the B-body cars have been out of production (even in the aftermarket) for decades. The best thing to do is to get some universal hanger rubber material, drill out the rivets on the old one, and rebuild it with new rubber. That universal hanger is likely your second best solution.
From the universal kit mentioned above, I used the new strap and nuts and bolts, along with the two original brackets (with drilled out rivets). It worked out well. Thanks to all for the advice.
