Seeking 1949-1955 Olds Manual trans Flywheel
Old Nov 13, 2023 | 01:52 PM
WyldWilly's Avatar
Seeking /Looking for a supplier / vendor for Flywheel / pressure plate / clutch for 1950-1955 olds Manual 3 speed transmission .for 303 -324 engine..Im in N Illinois ..Thanks
Old Nov 13, 2023 | 07:33 PM
Charlie Jones's Avatar
Phantom Phixer
There were two different flywheels used in the 1950 thru 1955 era.
A 145 tooth flywheel was used from 1950 thru 1953.
A 176 tooth flywheel was used from 1954 thru 1956.
What year engine do you need this for?
Old Nov 14, 2023 | 05:56 PM
WyldWilly's Avatar
303 manual trans parts flywheel
Is for a 303.. the year is unsure block stamp is R169591. Believe earlier 303.
Old Nov 14, 2023 | 07:53 PM
Phantom Phixer
According to that number stamped on the block, it is a 1953.
The transmission in your pictures is a 1950 Olds stick shift. (Cadillac built)
In any case you will need to find a 145 tooth flywheel.
Old Nov 15, 2023 | 11:21 AM
WyldWilly's Avatar
Thanks for your help.. greatly appreciated..
Dec 2, 2023 09:45 AM
WyldWilly
Nov 11, 2023 07:25 AM
66ragtop
Nov 17, 2017 09:22 PM
66ragtop
Sep 19, 2017 01:37 PM
Shot Gun Rich
Jul 7, 2014 11:34 AM
