Wanted - '73-'76 Radio Knobs
Old Mar 31, 2023 | 08:27 PM
SirVelociraptor's Avatar
Wanted - '73-'76 Radio *****
So I've been going through the painstaking effort to put a factory radio back in my Olds (including replacing the entire dash since the previous owner "skillfully" cut a massive hole in it for a touch-screen unit) and I am having immense trouble finding the correct, longer ***** that set inside the outer chrome ***** that were used in the mid-70's full size cars.
If anyone has a pair laying around that they can part with it would be greatly appreciated.
Old Apr 1, 2023 | 05:19 AM
Paladin31's Avatar
Radio
So you want any year (73-77) Olds radio *****, does it matter it is Cutlass or any model ?
and what about speaker & fader options etc ?
Brett
Old Apr 1, 2023 | 06:46 AM
Brett
As mentioned above I need the longer style volume / tuner ***** (the smaller, plastic, woodgrain ***** that fit into the chrome outer ***** shown below)
that were used in the full-size cars (Delta 88, 98 Regency).
The radios in these cars were recessed fairly far back into the dash and from what I've seen, are longer than ***** used on the Cutlass.
Old Apr 1, 2023 | 07:33 AM
jcdynamic88's Avatar
i believe the longer ***** came in 74-76 full size,71-73 aren't extended
Old Apr 1, 2023 | 09:25 AM
Paladin31's Avatar
These look to me to be A body only, but does the length look correct at least for comparison sake. ?
Brett
Old Apr 1, 2023 | 09:34 AM
Brett
I think you're correct in assuming those are for the A body radios. They look like they'd be just short of reaching the rod inside.
Old Apr 1, 2023 | 05:17 PM
Paladin31's Avatar
So here is the correct picture & info (ignore the headlight pull notation) for a 74-5 B-C car
hope this helps
Brett
Old Apr 23, 2023 | 07:44 AM
bigdooly's Avatar
If you haven't already found them I have a bunch.
Old Jun 10, 2023 | 05:22 PM
Paladin31's Avatar
If you haven’t found them yet, I did (finally)
Brett
transman74
Apr 7, 2023 09:11 AM
Gary's 2 442-S
Feb 4, 2018 05:57 AM
Jim B.
May 28, 2015 02:46 AM
71cutlassdroptop
May 18, 2014 07:39 PM
kevinalex
Jun 15, 2012 03:43 PM
