Quadrajet part
Old Jun 27, 2022 | 11:06 AM
uncle dave's Avatar
71 Cutlass Supreme Conv
Quadrajet part
Good afternoon fellow Olds enthusiast's. Working on a Quadrajet from a 1970 350, carb number 7040250 and I'm hoping someone out there has this pull off bracket that the previous owner found unnecessary and discarded. I've searched sites and found the pull off for sale but not this bracket. Don't understand why they would get rid of it, secondary's won't operate without it. Any help anyone an give would be greatly appreciated.
Old Jun 27, 2022 | 11:20 AM
The secondaries operate just fine without that diaphragm. The name is inaccurate. It is not a "pull off". Quite the contrary, the purpose of that diaphragm is to delay the opening of the secondary air valves - at part throttle the higher manifold vacuum retards the opening; at W.O.T. vacuum drops to zero and the air valves open more quickly. For a drag race only application, removing the diaphragm lets you set the secondary air valve opening solely with the warp spring. Of course, many people do stuff they see without fully understanding that a mod for the drag strip is usually NOT what you want on a street car.
Old Jun 28, 2022 | 07:11 AM
uncle dave's Avatar
Thanks for the info. Though I would still like to find this bracket. For it to work as it was designed. Just not having much luck. Don't intend to see any strip action.
Old Jun 28, 2022 | 07:15 AM
My response was to the "why" part of your question. Any bracket you find will likely come with a carb attached.
Old Jun 28, 2022 | 07:35 AM
edzolz's Avatar
I have stash buckets of parts. I will go through them and see if I have that part.
Old Jun 28, 2022 | 04:07 PM
newmexguy's Avatar
You might try a carb specialist, or better yet a Quadrajet specialist. They might have parts loose for sale.
Old Jun 28, 2022 | 04:31 PM
PatL's Avatar
https://quadrajetparts.com/used-parts-c-128_67.html
I did notice in their header they are temporary closed. I did business with them a few months ago and it went very well.
Old Jun 28, 2022 | 07:28 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Cliff will have it.
https://cliffshighperformance.com/
Old Jun 29, 2022 | 04:29 AM
ROCKETMAN269V's Avatar
Joe, I disagree with your statements regarding the operation of the secondary air valves. I you don't have the vacuum break (pull off) in use, the vehicle will tend to have a bog when you floor it. The vacuum break has a metering orfice in the tube where the hose is attached. By varying the size of the orfice, you can tailor how quickly the vacuum bleeds off at WOT to control the rate that the air valves open. The spring changes the relative point at which the air valves start to open. The tighter the spring is wound, the more air flow is needed to pull the air valves open. On our "drag only" Stock Eliminator car, we did a lot of tuning between the air valve spring and the vacuum break. On a cooler day, we would back off the spring tension by 1/8 of a turn to get the valves to open sooner, thus lifting the secondary metering rods to get more fuel to the engine. Obviously, there is much, much more to all of the fine tuning that goes into a Stock Eliminator national record setting car, but I just wanted to expand on your statement "The secondaries operate just fine without that diaphragm".
Old Jun 29, 2022 | 04:32 AM
Uncle Dave, I should have a couple of those brackets in my miscellaneous Q-jet parts. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jun 29, 2022 | 05:46 AM
Agreed, but that doesn't "prevent" the opening of the secondary air valves, it lets them open too soon. If all you care about is WOT performance at the drag strip, and you're launching the car at a high enough RPM, the engine vacuum is already close to zero and the dashpot is irrelevant. By eliminating the dashpot you can tune air valve opening with just the wrap spring. And once again, I'm in no way advocating this, I'm merely offering a rationale as to why someone would remove that part. This certainly isn't a mod one would use on the street.
Old Jun 29, 2022 | 07:34 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Here is another source. I just bought a fitting from them. They seem to be really good guys.
Quadrajet Power, Your One Stop Quadrajet Shop
Old Jul 1, 2022 | 08:23 AM
uncle dave's Avatar
Thanks, I just sent you an email.
Old Jul 5, 2022 | 07:45 AM
I couldn't find my Misc. parts, so I stole one off a carb core and I'll replace it when I find them. I'll send pics to your cell. Thanks, Bob.
Old Jul 5, 2022 | 09:23 AM
uncle dave's Avatar
Thank you Bob. That is the part. One less thing on my to do list.
Thanks to all for your suggestions.
Tom Bilse
Nov 5, 2019 02:03 PM
ELECMAN
Jun 30, 2014 06:35 AM
70442
Aug 5, 2013 06:40 PM
JOHNNYOLDS442
Aug 3, 2012 08:20 PM
stlbluesbrother
Oct 18, 2010 02:06 AM
