1963 oldsmobile dynamic 88
Old May 20, 2022 | 10:22 PM
Dros_olds's Avatar
Looking for upper control arms and or new ball joints.
Old May 21, 2022 | 04:24 AM
Ray Dzi's Avatar
Originally Posted by dros_olds
wow
looking for upper control arms and or new ball joints.
wow,beautiful car
Old May 21, 2022 | 10:16 AM
rocketraider's Avatar
Oldsdruid
Digging the whitewalls. A 60s car needs them.
You'll have to determine whether your 63 has TRW or Saginaw front end components to get the right parts. A 1963 Olds factory Chassis Service Manual will show you how to tell the difference.
I've heard from several early-60s big car owners that new old stock control arm bushings fail pretty quickly. I guess because the rubber is 50+ years old. I don't know if polyurethane bushings are available but they'd be a good option with the big wheels. Larger than stock wheels often put a big strain on original suspension components.
Any chance you have a good suspension shop close by? One that really understands suspension and doesn't just install 4WD lift kits?
Old May 21, 2022 | 05:03 PM
Charlie Jones's Avatar
Phantom Phixer
Nobody sells complete upper control arms. However, you can buy the bushings and replace them.
Fusick Automotive sells these bushings, as well as ball joints and other suspension parts .
Oldsmobile 88 98 and Starfire Suspension Parts-Fusick Automotive Products, Inc.
Old May 21, 2022 | 05:24 PM
Phantom Phixer
This only applies to steering parts, such as center links and idler arms.
Fortunately the ball joints and control arm bushings are all the same . With no TRW / Saginaw differentiation foolishness.
Old May 21, 2022 | 06:34 PM
mpolds's Avatar
U S A made Ball Joints & Control Arm Bushings
As indicated correctly, by Charlie Jones above, there is *** NO NEED *** to have to do the
T R W / Alternate Design versus Saginaw Design --- that strictly comes into play for all the Steering Components--- Center Link & Idler Arm, Inner & Outer Tie Rods & Sleeves......
For the Suspension Parts --- Upper & Lower Ball Joints & Upper & Lower Control Arm Bushings--- there is only one set up for every 1963 Full Size OLDSMOBILE--- 88 , 98, Holiday, and Starfire......
I have *** U.S.A. made *** Upper & Lower Ball Joints and Upper & Lower Control Arm Bushings *** in stock, for your car.....
Always best to simply call me --- 516 - 485 - 1935 --- Craig......
Old May 21, 2022 | 07:43 PM
Oldsdruid
or Craig (mobileparts) can guide you thru it! Charlie Jones too!🙂
Old May 22, 2022 | 02:50 PM
65B01Delta's Avatar
Very nice looking ride,
12dwilson1992
Nov 10, 2021 10:36 AM
Bigbassape
May 8, 2021 05:28 AM
dynamic88girl
Jul 28, 2011 08:32 PM
venturaneil
Jul 28, 2011 02:36 PM
Big Joe P
Mar 2, 2007 11:12 PM
