380145 #2 Manifold WTB
Old Feb 13, 2022 | 05:28 PM
Miguel-x's Avatar
Wanted To Buy: 330 Jetstar B body driver's side manifold. 380145 #2
Old Feb 13, 2022 | 05:34 PM
That's going to be a tough one. Only used on the 1964-70 B-body cars with small block. The 384785 used on the big block cars is a lot more common but taller. You MIGHT be able to make it work in a pinch, but the crossover pipe would be custom. Here's a comparison. 380145 on the left, 384785 on the right.
Old Feb 13, 2022 | 06:28 PM
Miguel-x's Avatar
Research tells me the BB manifolds will bolt to SB heads but hit the engine mounts. Is this true if the mounts are bolted to the front two holes? It does look like the dumps are in the relative same area and since I am fabricating mounts anyway I can place the engine front to back to fit, but it does look like the BB manifold is taller.
Old Feb 13, 2022 | 06:47 PM
Miguel-x's Avatar
Oh yeah... then there's the starter. Maybe a HT mini starter would clear.
Old Feb 14, 2022 | 05:08 AM
Your on-line research will only find references to using W/Z manifolds on SBOs. That has nothing to do with this. Go back and look at the photo I posted. The only apparent difference in the center-dump manifolds is the length of the outlet section that doesn't even come close to the motor mounts.
Old Feb 14, 2022 | 06:52 AM
edzolz's Avatar
I might have on of these manifolds in my extra parts box. I will check today and get back. $100 plus the ride if I have one.
Old Feb 14, 2022 | 09:11 AM
Miguel-x's Avatar
It may simply be an illusion of perspective from your pics but the BB manifold does appear, to my eyes, to be larger in the body as well as the length of the dump. Hence "looks taller'.
Old Feb 14, 2022 | 09:14 AM
It may simply be an illusion of perspective from your pics but the BB manifold does appear, to my eyes, to be larger in the body as well as the length of the dump. Hence "taller'.
It's not. The photo is at a slightly different angle. Unfortunately I didn't have both manifolds in the same place at the same time for one photo.
Old Feb 14, 2022 | 01:41 PM
edzolz's Avatar
Sorry the one I have is an "A" 385785
Old Feb 14, 2022 | 04:47 PM
oldolds88's Avatar
ill check my stash
Beenz
Apr 11, 2016 04:36 AM
marklt
Nov 26, 2015 07:49 AM
easyd
Aug 31, 2015 05:00 PM
at3reg98
Apr 14, 2013 02:04 PM
1969w3155
Jul 18, 2012 09:21 AM
