67 Rochester Carb Baseplate
Old Jan 17, 2022 | 07:19 AM
68442's Avatar
Looking for baseplate 7038294. Application is 1967 7027157 or 7027157
Old Jan 17, 2022 | 07:54 AM
tru-blue 442's Avatar
Old School Olds
It may be no better than the one you have but it's yours for the cost to ship it.
If nothing else folks will be able to tell where the #'s are if they wanted to hunt one up.
Old Jan 17, 2022 | 08:06 AM
68442's Avatar
Do you have additional pictures showing the levers etc.
THANKS
Old Jan 17, 2022 | 10:22 AM
Old School Olds
It's locked up and has one mixture screw broken off in it. I'm not even sure where I got it. Probably from the parts stash I bought years ago.
Old Jan 17, 2022 | 11:40 AM
68442's Avatar
What i am finding is this part number has been used for a variety of years and applications with different vac. ports and throttle shafts. That is why i asked for the additional pictures .
This looks like a 70-up Application based on the throttle lever.
Thanks for the willingness to help out !!!
Still looking/need
Old Jan 17, 2022 | 11:47 AM
Old School Olds
No problem, good luck.
Old Jan 17, 2022 | 12:47 PM
That is correct. Rochester used the same basic castings on many different carbs. Throttle shafts and levers, vacuum ports, and other features could be different. You'll need one specifically from a '7032, '7156, or '7157 carb. The base plate from a '7036 (1967 330 4bbl) should work also.
Old Jan 18, 2022 | 05:20 AM
68442's Avatar
The baseplate from a 7032 and the 7036 may "Work" but it carries a different number 7032502.
Old Jan 18, 2022 | 06:21 AM
The baseplate from a 7032 and the 7036 may "Work" but it carries a different part number 7032502.
Is that the casting number or the part number? I suspect the casting is the same, but the P/N difference might be due to an extra vacuum port - especially on the '7032 which was the C.C.C carb.
Old Jan 18, 2022 | 01:00 PM
68442's Avatar
I'm going by the casting number that is stamped in the little circle on the mounting ear
Old Jan 18, 2022 | 01:02 PM
That's interesting
Old Jan 18, 2022 | 01:09 PM
allyolds68's Avatar
Do 67 bases have a date code like 68's? Just wondering because if they do the date may matter as well
Old Jan 18, 2022 | 01:25 PM
68442's Avatar
Hey Mike, I'm Drawing the line with my sanity to just find the correct baseplate. I have no concern with a date code, However the ones i have seen did not have a date code stamping, Coincidence??
Old Jan 18, 2022 | 01:29 PM
68442's Avatar
That's interesting
For reference there are a few 67 330 carbs on ebay. I reached out to the sellers to get the casting numbers and they are the 7032502
Old Jan 21, 2022 | 10:46 AM
nicks1966's Avatar
Some pictures of the 2502 base plate for comparison.
this one is off a 67 330 carb
irydasteelhorse
Nov 5, 2021 02:25 PM
oldaman
Jan 8, 2020 06:37 AM
NotDads442
May 24, 2018 06:56 PM
CQR
Jun 30, 2011 04:46 AM
MN71W30
Sep 13, 2010 06:47 PM
