68 442 Spark plug retainers for brackets.
Old Jun 10, 2021 | 05:26 AM
W-27's Avatar
I am looking for both of the black plastic spark plug retainers that go on a 68 442 engine.
Old Jun 10, 2021 | 11:16 AM
69 Hurst's Avatar
Olds Fanatic
Are you referring to these?
Or the ones that slide onto metal brackets?
Old Jun 10, 2021 | 12:42 PM
W-27's Avatar
The one at the bottom (which goes to the driver side) then there is one that goes on the passenger side that also slides into a metal bracket but it only hold (2) spark plug wires.
Old Jun 10, 2021 | 12:45 PM
W-27's Avatar
Picture of bracket.
I have the bracket on the driver side but not the passenger side.
Old Jun 10, 2021 | 02:30 PM
rcorrigan5's Avatar
Randy C.
I seem to recall someone mentioning that the Pontiac GTO of that same era also had the same or similar bracket and two wire holder for the passenger side that is being reproduced. You might want to check some of the Pontiac parts providers to see if they do have something that looks authentic enough (either identical or close to it) that you can use for the passenger side.
Randy C.
Old Jun 10, 2021 | 04:41 PM
W-27's Avatar
Randy, thank you for that advise. I will check into it....if i could only find the passenger side bracket.
Old Jun 10, 2021 | 05:07 PM
69 Hurst's Avatar
Olds Fanatic
That bottom one is available from OPGI.
Old Jun 10, 2021 | 05:15 PM
rcorrigan5's Avatar
Randy C.
...and I've heard the passenger side bracket and wire holder are reproduced on the Pontiac side but I haven't researched it myself.
Randy C.
Old Jun 10, 2021 | 07:36 PM
W-27's Avatar
It's funny because OPG sells it for $23.99 but OldBuick.com sells the exact same part for $4.75 it pays to shop around.
Old Jun 11, 2021 | 04:24 PM
Yellowstatue's Avatar
I thought that two wire bracket was only used on the passenger side.
Old Jun 11, 2021 | 04:56 PM
Loaded68W34's Avatar
If you are only looking for the plastic part it should be the same as the lower ones pictured below. These are for BBC and any classic chevy parts dealer should have them. If you cannot find the metal bracket, it should be easy enough to make something close.
Old Jun 11, 2021 | 04:58 PM
The one at the bottom (which goes to the driver side)then there is one that goes on the passenger side that also slides into a metal bracket but it only hold (2) spark plug wires.
Old Jun 12, 2021 | 07:38 AM
W-27's Avatar
It's all in the details
Out of all four of them i can only use (1) of the two wire holders as the four wire holder is different than the original as the one wire all the way to the right as a larger separation from the other three (see the first picture all the way to the beginning of the thread) which can actually be purchase separately. It would be nice if companies like Inline Tube reproduced a complete set just like the original set. One year only parts.
Old Jun 12, 2021 | 01:14 PM
I realize the olds 4 wire is different, but you asked where to find a two wire holder as well. This is why I said what you are looking for should be the same as the lower ones in the picture. You may be able to find them separately, but if not, you can find BBC sets for less than $15 and buy the 4 wire olds piece on its own.
https://www.ebay.com/itm/23087979662...cAAOSwTA9X78jK
Old Jun 12, 2021 | 01:22 PM
W-27's Avatar
That is problably what i will end up doing. Thank you for your help.
W-27
Jul 18, 2021 07:54 AM
W-27
Dec 7, 2020 09:24 AM
chasman414
Oct 30, 2014 03:15 PM
craftsman1956
Jul 7, 2010 08:29 PM
