I would have to go looking but I think I do. My car has a 1967 rally pac and I'm going to pull it in a week or two. I also have a pristine ralley tic tock clock that is fully restored, 1967. Send me a pm and I'll give you my phone number. I'm in Texas.
HI Roy34,
Have you had a chance to look for the rally pac dial yet? I am not in a big hurry but just wondering if you got my first message.
thanks,
Bob Swem
I did not see your other message? I have two ralley packs. One is in my car right now and the other is in my garage. The one in my garage was completely restored 13 years ago and is in mint/perfect condition. I have paper work as well. I have a second one that I purchased and it is in my 67 supreme. Supposedly, it was in perfect running condition when it was put into my car. It never worked because both myself and my mechanic at the time did not know or realize that you needed the correct motherboard. The cluster that is in the car now will be pulled next month as I am doing a frame off restoration. I will be installing aftermarket instruments. When I pull the one in the car, I was going to send it off to be bench tested and then I was going to sell it. Are you interested?
I might be interested in the one in your car. I have a 67 post coupe that I installed a ralley pac in about 10 years ago. The dial is really bad so I need a new dial. What would you have to have for the one in your car? You say it has never worked? Could you shoot me a picture of it.
Hi again Roy34,
I thought overnight what I might offer for the ralley pac but to make the offer as good as it should be I would really like to see a picture or two of the gauges. As i understand it the gauges are installed in your car that you are going to do a frame off soon and the gauges have never worked because of a motherboard problem. If you wouldn't mind could you remove the bezel from the ralley pac ( just two screws and the clock ***) and take a look at the center connector. It should be a rectangular connector with a row of contacts on the upper and lower side of the connector that contacts the circuit board the gauges are mounted on. If you can take a picture of the dial head on and a picture of the connector then I think we will have a better chance of a fair offer for both of us.
best regards,
Crow 442
Just for comparison:
I sold these a few months ago on eBay. What you see in the pics is all I had. I sold them as a set. 7 day no reserve auction with an opening bid of $600. The final bid was $950.00 plus shipping. These were untested and obviously would take a lot of work to try to make the correct metal back plate to accept the printed circuit board. Not sure who would cut apart a perfectly good rally pac or for what reason, but this is how I got them.
