'65 cutlass power steering parts wanted
Old Jun 7, 2009 | 10:17 AM
65az's Avatar
Need everything.. gear box, pitmann arm, hoses, power steering pump with pulley, and the bracket for the engine. running a 77 403, not sure if it will be a different bracket than for a '65.
Old Jun 7, 2009 | 10:53 AM
2blu442's Avatar
Do you know what year of pullys your using? Are they the ones from the 403 or 330? If you don't mind used I probably have everything although the shipping might get expensive. I am concerned about your belts lining up. There have been some discussions about using a matched set of pullys to prevent that. I'm not sure if the power steering pump pully is critical to that or not. Unless you already know, you might post a question on the discussion board to see what other guys think.
If you decide to go with a rebuilt gear box or can find some of the heavier items closer than Oregon let me know if you get stuck on anything else. John
Old Jun 7, 2009 | 12:16 PM
Warhead's Avatar
Send me a note, Chris.
If you can hang on for a couple more weeks, I may be able to get you everything, minus the pitman arm.
I have some parts in the works.
Jim
Old Jun 8, 2009 | 08:39 AM
65az's Avatar
I am assuming that the pulleys I am running now are from the 403.. but I really don't know since the motor was put in before I bought it.
c-towndave
Apr 14, 2014 07:38 PM
nicks1966
Jan 12, 2014 01:46 PM
59Olds98
Oct 16, 2013 12:12 PM
russell-t
May 1, 2011 08:57 AM
dingusboy
Sep 7, 2010 12:17 PM
