1965 olds 425 pistons
i need a set of 1965 olds pistons . have shopped around and found them with kanter egge mondello please respond if you can supply your your me with knowledge on whats good and whats bad
All of the aftermarket cast pistons are shorter than factory so the compression ratio will be less than expected unless you do some machine work to compensate.
Cutlassefi (Mark) on this site has introduced a forged piston that is the correct height, is lighter, and uses a modern thinner ring pack, all of which result in more power and reliability.
