Wanted for 1967 Delta 88
Old Dec 31, 2018 | 06:06 AM
UPDATE 1/29/19:
I've scored some of the parts thanks to members here. Still need the wheel opening trim and I forgot the rear bumper fillers.
Need the following for my 1967 Delta 88 Holiday Coupe.
  • Both rear rubber bumper fillers (these are not reproduced)
  • Left front fender extension. Mine was hit and tweaked. You can't straighten pot metal. All 1967 full size are the same.
  • Front wheel opening trim. Must be for a Delta 88 - Delta Custom and Delmont are different. A prior owner cleverly put screws through mine to hold it in place.
  • Inside left (driver side) A-pillar trim. Mine is the optional anodized aluminum, not painted steel. This is unique to holiday coupes. Bonneville is apparently the same. A prior owner cleverly drilled a big hole in mine for a spotlight.
  • Front license plate bracket.
Thanks. Shipping will be to zip code 20180, or I can pay now and pick up at Spring Carlisle.
Old Jan 15, 2019 | 01:43 PM
Bump. C'mon, somebody must be parting a 67 full size. Need to get this car done for Power Tour.
Old Jan 15, 2019 | 04:07 PM
jcdynamic88's Avatar
front plate bracket and pillar trim different for 66?
Old Jan 15, 2019 | 05:04 PM
The plate bracket is different, but the A-pillar trim is apparently the same on all 66s except convertibles. I'm looking for the chrome (actually anodized aluminum) trim, not the painted ones. I'll take them if you have them.
Old Jan 15, 2019 | 07:20 PM
the previous owner of this 66 was using a delta and a starfire for donor cars and there are plenty of loose trim in the trunk.i may have saved the plate bracket from the 67 delmont i had,i know the car had old mass plates on it when i got it.i will try to look for it,my parts shed is a mess
Old Jan 20, 2019 | 05:39 AM
Delmont1968's Avatar
Parting out a 1968 Delta Custome
Hello Joe, I am parting out a 1968 Delta Costume 4 door. Don't think the fender extensions will work, and not sure of the chrome. There will be plenty of other parts that should be interchangeable between a 67 and 68. Feel free to touch base if I can be of service. Live around Morgantown WV.
Old Jan 20, 2019 | 06:33 AM
Thanks. Unfortunately none of the front sheet metal or chrome interchanges between 67 and 68. For example, the 68 cars have a parking light where the 67 has a fender extension. Also, the chrome interior trim was apparently only used on 66 and 67 cars according to the parts book. Do you happen to know if your car has the Pontiac 8.875" rear axle or the Type O 9.3" axle?
Old Jan 20, 2019 | 07:20 AM
Axles
I have not looked. I may have some time tomorrow to check it out for you.
Old Jan 27, 2019 | 04:36 PM
2blu442's Avatar
Joe, have you found the A pillar trim yet? I really don't think I've pulled parts off of a 1966 or 67 Olds 88 but on the off chance I don't remember I've dug out some anodized A pillar trim. I know I've got another set somewhere but haven't come up with it yet. If any of these look close to the size/shape I can take more measurements or photos. Let me know what you think. John
Old Jan 28, 2019 | 02:20 PM
John, I've found what I need, but I might be interested in a spare just in case. Unfortunately none of those look right. Let me get a photo of mine. Thanks.
Old Jan 29, 2019 | 01:52 PM
Bump
See edit in first post.
Old Jan 8, 2020 | 10:50 PM
rocketscientis's Avatar
Joe kmows
On drivers side , in front of a/c condenser mounted to the lower portion of core support is a cylinder couple inches in diameter , about 4 " long with openings L&R & a wire runs through that up to a squareish black metal box...foundbuild sheet under carpet in rear behind driver but it will take sum doin to extract it & low on list atm...67 B - body 4 dr
can get pix but mite hav to clean up first as quite certain I'll crap kittens should day arive you are either unknowledgeble or incorrect
Thanks for th help
Jake Mack
Apr 9, 2016 08:25 AM
DownBoy
Mar 31, 2014 08:25 AM
Mak
Jul 17, 2011 10:41 AM
TennesseeDelta
May 17, 2011 02:01 AM
DenVIP
Apr 8, 2009 06:08 PM
