need all the parts
Old Aug 27, 2018 | 04:47 PM
Frankied37's Avatar
need all the parts
Hey guys I have an 1976 Oldsmobile cutlass 442 and I need
- grill inserts
- front passenger molding under lamp
- rear passenger molding under lamp
- the filler panels on the right and left side right in front of the rear bumper to fill it in to the rest of the body
- dash pad
- panel to attach headlight switch and wipers
- panel that attaches under the steering wheel to cover up wires
-any interior trim panels as mine is beat up and full of holes
interior is tan and I an located in upstate new York.
Old Aug 27, 2018 | 06:27 PM
76olds's Avatar
Hookers under Hood
You can get the rear bumper fillers from Fusicks , I purchased a pair last year had them painted and they fit perfect.
Good luck on your search, some guys will have what you are looking for.
Eric
Old Aug 27, 2018 | 06:30 PM
Frankied37's Avatar
Eric
Thank you!
Old Aug 27, 2018 | 07:53 PM
crimsoncolby's Avatar
I've got this nice dash panel I removed from a '74 Cutlass Salon. Might be overkill for you since it has the Rear Defrost switch and I'm trying to sell it with the rear blower ***'y that came with it. Have the matching RH panel with Temp Controls, too.
I've got some misc. interior plastic headliner trim pcs and "A" pillar trims in various colors if these are what you are referring to. DO NOT have any sail panel trims, though. VERY hard to find those without dry-rot. You will be extremely lucky to find all these pcs in the light tan color. Thus, you'd best be prepared to gather what you can find in any color with the idea of painting them to match.
Old Aug 27, 2018 | 08:15 PM
Frankied37's Avatar
Panel looks right. I have the sills already in good shape, I need the a pillers on both sides and kick panels. Do you have a picture of the temp controls? Thanks
Old Aug 28, 2018 | 07:10 AM
Here is a pic of the Temp Control/Radio dash panel from the same '74 Salon. I've come across a lot of these at the JY's I have available in my area and these are definitely the best ones I've seen.
Regarding the LH panel with the Rear Defog...it's an easy addition to install if you don't mind cutting the two openings in your rear package tray. The openings are already provided in the metal shelf under the package tray for guidance and the wiring is a simple plug and play into your fuse box (complete wiring harness is provided). Anyway, ask if you have any questions.
I've got the two "A" pillar trims in Dark Saddle and Black. Kick panels in Black and Oxblood Red. All pcs are in excellent condition without dryness associated with most.
Old Aug 28, 2018 | 08:07 AM
Frankied37's Avatar
I’m interested in the Lh panel for now and the trim, I may need a couple more trim panels I will check when I get home. Email me at Frankied8642@gmail
so we can talk more
Old Aug 28, 2018 | 05:33 PM
76olds's Avatar
Hookers under Hood
crimsoncolby,
I haven't seen dash inserts in that kind of condition for years. The trim pieces as well , most I have seen are dried up, cracked and turning to dust. Its very hard to find a nice set of dash inserts like the ones posted .
If Frankied37 has found others or not interested, PM me a price please.
Eric
Jon442
Apr 12, 2018 07:09 PM
Rios69Cutty
Jul 28, 2013 02:52 PM
Al Graaf
Jul 2, 2012 08:39 PM
thunder66
May 21, 2012 08:38 AM
Col Wickham
Nov 19, 2009 04:58 PM
