Wanted 68-71 Bellows style Cruise Control Servo
Old Aug 21, 2018 | 07:48 AM
OldsAl's Avatar
Looking for a 68-71 “bellows” style cruise control servo. These were used on both full size and A body cars. Also interested in other cruise control parts including the servo mounting bracket, adjustable rod and the 2 piece linkage that mounts on the intake manifold. alsutton@shaw.ca
Thanks, Al
Old Aug 21, 2018 | 10:19 AM
vistacruiser1971's Avatar
Olds Collector
Bellows Style Cruise
Hi Al: Is this the kind you need? This was installed on my 1973 Pontiac Grand AM. Regards, Trent in Los Angeles
Old Aug 21, 2018 | 10:50 AM
OldsAl's Avatar
Hi Trent. Sorry got your email and replied before I saw your response here. This is the type of servo I am looking for.
Old Aug 21, 2018 | 01:35 PM
Olds Collector
Al: No problem, I replied to your email before i saw your photo here!! Good luck with the search, love this site. Regards, Trent in Los Angeles
Old Aug 22, 2018 | 06:16 PM
pops1958's Avatar
"I need a couch"
I have this piece..seems like I had some linkage too at some point. Did not see it when I first looked. Send me a photo of what else you need.
you tell me If it's what your after & what it's worth. If you buy it, you'll have to promise 1st crack at that burgundy machine..ha
Old Aug 23, 2018 | 09:15 PM
code26's Avatar
Cruise servo
this one is on eBay linkage mount is different
File Type: png
Old Aug 23, 2018 | 09:58 PM
OldsAl's Avatar
AMC also got smart with the leak down issue with vacuum cruise control servo's and added that outer ring to improve sealing on the outer 2 plates. Although this particular servo shares the same diaphragm and front plate Oldsmobile used a different style rear plate that had a ball style connection for the adjustable linkage rod to snap onto. Oldsmobile also used a modified outer ring from 1973 till about 1979 to help stop vacuum leak down. There's a basic test in section 15 of the chassis manual to test a vacuum servo. You compress the servo and put your finger over the vacuum inlet. If the servo remains collapsed its functioning properly. If it expands back or leaks down you either have a tear in the servo rubber or a leak past one of the outer plates. If your outer plate is leaking you can take off one plate at a time and put a small bead of Vaseline in the outer edge and reassemble or use clear silicone. I digress...
Code 26 thanks for posting that one but I am looking for a 69-71 Oldsmobile style servo like the one Pops1958 posted. Pops1958 I appreciate you posting yours too but I think I will keep looking for one in better condition. Al
matt69olds
Nov 28, 2018 12:53 PM
1BOSS83
Mar 24, 2016 04:56 PM
WendellB
Apr 27, 2015 12:46 AM
RandyS
Jun 16, 2013 10:08 AM
425HP409
Jul 13, 2011 03:03 PM
