Wanted: circuit board for my 1969 4 speed or who may refurbish mine.
Old Mar 28, 2018 | 06:42 PM
pops1958's Avatar
"I need a couch"
Looking for advice and/or purchase...my gas gauge & oil pressure gauge suddenly went out at the same time. My friend who is helping me is convinced it's a faulty circuit board. I was surprised to find they were not reproduced specifically for Olds 69 442's. (Aren't they reproduced for say a 69 ChevelleSS?)
Anyhow, my car is a 4 speed console, Am radio, no a/c, w/gauge package.
Any help is greatly appreciated.
Old Mar 28, 2018 | 07:32 PM
tru-blue 442's Avatar
Old School Olds
Try Scott. He may be able to help.
https://classicoldsmobile.com/forums...el-gauges.html
Old Mar 28, 2018 | 07:49 PM
Nice car! Hope you get it sorted out.
Old Mar 28, 2018 | 09:50 PM
RandyS's Avatar
Circuit boards usually don't just go bad all of a sudden. It takes a major jolt or power surge to break or burn a trace. In almost every case, a board with a broken trace can be repaired. First thing to check is that the large round plug on the back is securely seated.
Old Mar 29, 2018 | 04:56 AM
RetroRanger's Avatar
72 Olds CS
Look up miles71 69 convertible thread he recently documented some repairs to the board on one of his gauges. Loose pins very common on the 68-72 a bodies
Old Mar 29, 2018 | 04:59 AM
72 Olds CS
Link
https://classicoldsmobile.com/forums...nvertible.html
Old Mar 29, 2018 | 06:43 PM
Most likely there are a few pins loose or broken off the board. I pulled one pin loose (and part of the circuit board trace with it) unplugging the connector from my Rally Pac. If your even the slightest bit comfortable with a soldering iron you can easily repair it. I removed all the pins (there were several loose) and replaced them with very small screws. I found the perfect size at a hobby shop. I fixed the broken circuit board trace with some small gauge wire. Or, as suggested, call Scott
Old Mar 30, 2018 | 05:07 AM
cdrod's Avatar
Rodney
It sounds like your friend is just guessing it's the circuit board, unless there are broken pins or visible evidence of bad circuit traces. When multiple systems fail at the same time you need to look for what they have in common. I would check for bad ground connections first before dissecting your gauge units. Here's a page from the assembly manual that shows the grounding straps for the gauge units. You can test for bad grounds by making your own ground wire to bypass the dash straps to a known good grounding point. I hope this helps.
Rodney
Old Apr 4, 2018 | 07:02 AM
pops1958's Avatar
"I need a couch"
Classic-olds is the greatest! I have followed all the collective wisdom and believe the problem is solved..loose pins, not the cardboard. I have had it repaired by someone on this site. Thanks to all!
55chevycraig
May 23, 2013 05:47 AM
antweave
Apr 22, 2013 07:26 PM
bobfo1
Jul 23, 2011 05:59 PM
yugsdlo88
Apr 20, 2011 05:58 PM
KQQLCAT
Nov 12, 2008 07:31 AM
