side by side master window switch NEEDED
Old June 18th, 2017, 06:18 AM
Hause's Avatar
For my 1987 Olds 98 Regency Brougham 2-Door
Hause is offline
Old June 18th, 2017, 06:32 AM
toymobile's Avatar
I have one I saved but no longer need, where are you located.
Johnny
toymobile is offline
Old June 18th, 2017, 06:40 AM
Hause's Avatar
Side by side master window switch 87 Olds 98
Hause is offline
Old June 18th, 2017, 07:00 AM
Hause's Avatar
I'm located in Webberville Michigan. I'm new to this forum so not sure how to make a transaction.
Hause is offline
Old June 18th, 2017, 08:12 AM
toymobile's Avatar
The one I have is different, Sorry
Old June 18th, 2017, 10:18 AM
Hause's Avatar
That sucks! Got my hopes up. Thanks anyway.
Hause is offline
Old June 18th, 2017, 05:02 PM
Olds Fever
CRUZN 66's Avatar
Like I said in your other thread you could remove your switch and possible clean the contacts, or even check for a broken wire... If you are still having a problem I will pull out one of the four button switches I told you I had and see if there is a way to adapt it or use part of it to repair your two button...
CRUZN 66 is offline
Old June 19th, 2017, 03:47 PM
Olds Fever
CRUZN 66's Avatar
Here are a 4-button and a 1-button switch with wires... If you can't find a 2-button, maybe you can adapt one of these...
CRUZN 66 is offline
Hause
June 15th, 2017 04:07 PM
tds
July 11th, 2014 08:09 AM
Delta88Vert
August 12th, 2012 11:39 AM
69convertible
December 7th, 2008 02:03 PM
maraz52
August 15th, 2008 09:24 PM
Quick Reply: side by side master window switch NEEDED
