407567 455 Intake
Old Mar 15, 2017 | 03:30 PM
4R5's Avatar
4R5
407567 455 Intake
Hi, I had posted previously looking for a 404521 “L” iron 455 intake, but further research says that the 407567 is correct for a '71 455 A or B body with T400. 442.com says the 407567 is for stick only '70 thru '72 and 404521 is auto '70 thru '72, but my '72 parts book shows the 404521 for 70, 407567 for '71 and 231399 (never heard of this one) on the '72s. Looking for one with a date code between 125 to 155. Thanks!
Old Mar 15, 2017 | 03:34 PM
442crzy's Avatar
Intake 71 455
PM sent
Old Mar 16, 2017 | 01:36 PM
ROCKETMAN269V's Avatar
Originally Posted by 4R5
......442.com says.......404521 is auto '70 thru '72.........
From the 442.com FAQ: L 404521 '70-'72 455 4V AT and MT. W-33, 442, SX, 88, 98's. Except W-30. Iron.
Old Mar 16, 2017 | 03:14 PM
4R5's Avatar
4R5
Got it, but my '72 parts book shows the 404521 for 70, 407567 for '71. I'm not confident 442.com is 100% accurate.
Old Mar 16, 2017 | 03:23 PM
11971four4two's Avatar
MOTORHEAD
I thought the $ 4 speed intake had a "nipple" for PcV drilled / installed to the front of carb. Same cast Iron manifold. Just no nips for automatic cars
When I get a chance I will look under hood of 1971 and see what casting #'s I can find
Happy motoring
b
Old Mar 17, 2017 | 07:05 AM
Don't confuse casting numbers with part numbers. For example, 404521 is the casting number for the 1970 intake and is also the part number for the 1970 AT intake. The 1970 MT intake is the same casting number but has the PCV nipple, so the PART NUMBER is 404848.
Imagine that...
According to the 1971 Engine Assembly Manual, the intake casting number is 407567, which is also the P/N for the AT version. The MT version uses that same casting number but has the nipple so P/N is 407568.
Old Mar 17, 2017 | 07:17 AM
4R5's Avatar
4R5
Thanks Joe, I appreciate the info! Yes, I am aware of the part # vs. casting #. I had seen a picture here on CO of a '71 intake with the 407567 casting #. But as I mentioned I was led to believe the 404521 was the correct # for my 71 VC (455 4bbl). So I'm going to conclude that I need the 407567.
On a side note, is the Engine Assembly manual available as a reprint? I see it's referenced in section 6 of the Car Assembly manual, but have never seen one.
Old Mar 17, 2017 | 07:44 AM
Here ya go (scroll to Post #9)
https://classicoldsmobile.com/forums...tml#post856534
Old Mar 30, 2017 | 10:56 AM
4R5's Avatar
4R5
Bump, still looking, thanks!
Old Mar 30, 2017 | 02:55 PM
442crzy's Avatar
Intake manifold
I have no problem taking the one off the engine, lmk if that works for you, thanks
Jan 23, 2016 06:48 AM
lunaboy
Oct 15, 2015 07:09 AM
brandon reynolds
Dec 14, 2013 01:09 PM
507OLDS
Oct 18, 2012 07:56 PM
svnt442
Jul 17, 2011 04:43 PM
