I need ...
Alternator Bracket Wanted 1971 Cutlass WITH A/C
This bracket mounts on the DRIVER'S SIDE.
I can find the bracket for the NON A/C vehicle everywhere.
But no luck finding this one.
Thanks for your response. However, I'm looking for an alternator bracket for a 1971 cutlass with I repeat with air-conditioning. Let me know if you have anything in that regard. Thanks
These are from a 70 A/C car and mount to the driver side. I can not remember if the 71 is the same as 70 or the same as 72? I have the newer style also if that is what you need.
The brackets Eric posted are correct for 68-72 big block, including the 68-69 400 442's w/ac.
I have no idea of the brackets for the s/b engines. I assume they are the same but
would use a smaller belt. PM sent on the H bracket Eric, thanks.
I have not heard back from robs71 yet. If oldspackrat has one go ahead and get his. I likely have more of these but at this time it is the only one I can find.
If you see the part you want in this picture, it is for sale.
Heck you can buy the whole lot of brackets, alternator, fan, A/C compressor and brackets, etc.
Manifolds and sway bar not included in this sale.
