I am looking for a dipstick tube for a 73-74 455. Mine was in the box of parts that came ith my motor and long story short it's kinked in half. Call or text me of possible, thanks in advance 920-517-6093
There are two oil indicator guide tubes you can possibly use... part number 401357 is for 69/73 455 and 417091 is for 74/75 455 as called out in GM parts manual... Don't know why there is a difference between 73 vs 74 but the bends are different, most likely because of exhaust manifold configuration... In the photo below, top one 417091 and bottom is 401357... I have both of these NOS... $25 each plus shipping in the US only...
I'll check the weight and let you know... Priority mail should be somewhere between $10/$15... But I'll run the numbers just to be sure... Do you know which one you will need?
Sounds good, i have a 74 block and the w z manifolds so let me know what tube would work best
I have no idea which tube will work best for your application... what do the bends look like in the previous tube you used? Maybe someone on here has used the w/z manifolds on a 74 and later 455 and can provide you some information...
