WTB: Proportioning Valve
Old Nov 5, 2019 | 07:06 AM
friesjh's Avatar
Hello all,
Looking for a clean proportioning valve from a 1971 Vista or Custom Cruiser. Would like as much of the wire going to it as well. LMK
Old Nov 5, 2019 | 08:36 AM
Originally Posted by friesjh
Hello all,
I assume you are looking for the original cast iron style?
Old Nov 5, 2019 | 11:24 AM
friesjh's Avatar
Yes sir.
Old Nov 10, 2019 | 08:24 PM
rocketscientis's Avatar
Prop valve
Is that drum or discs ?
Hav 72 w/drums if thats helpful ??
9897219432...cal or txt
Old Nov 11, 2019 | 06:32 AM
And there is still no such thing as a "proportioning valve" for four wheel drum brakes...
Old Nov 13, 2019 | 12:30 PM
friesjh's Avatar
I guess the parts manual does call it a brake balancing & metering valve. Looking at the part numbers it's the same valve for drum and disc. Looks like the 71-72 and also 73 at the bottom of the picture, is what I'm looking for. p/n 5472140
Old Nov 13, 2019 | 12:47 PM
Only on the Toronados with drum brakes, but good catch. I can only assume this had something to do with the heavy front weight bias on those cars. Of course, the OP is talking about an A-body.
From the 1969 CSM:
Old Nov 13, 2019 | 01:11 PM
friesjh's Avatar
So it looks like any of the 71-73 VC will work.
Old Dec 14, 2019 | 08:42 PM
friesjh's Avatar
Still looking for a good used proportioning/combination valve w/switch from a 71-73 Vista Cruiser. PN 5472140.
Old Dec 15, 2019 | 12:23 PM
Ha
Hav 2 77 vista cruiser wagons that never vista'd & have seased cruising by chance would theirs b sufiecient ??...hav also noticed th shorty 68-72 Chevy van W/discs has that aperatus as well also thought th 73-7 elcaminoes may fit your critrtia...got 1 those as well
Old Dec 15, 2019 | 01:22 PM
friesjh's Avatar
I did more research and it's looking like the part number is superseded by 5472359, then by pn 18004050, then by pn 1257177. Looks like 71-72 Toro and 73-74 X body Olds will work as well. Doesn't look like any of the Chevy's are correct, although I'm not sure what vehicles came with the 1257177 pn. I was unable to locate the GM parts catalog page for that number. So just to be clear I don't need the balance valve in Joe's picture above. I'm looking for the distributor and switch in that same picture. The follow are the vehicles built with the valve I need:
71-73 Vista and Custom Cruisers
71-72 Toronado
73-74 Omega
Please let me know if anyone has an original cast iron valve from one of the vehicles in the list above.
scott_442
Jul 31, 2017 07:15 AM
hp192
Cars Wanted
May 18, 2017 02:23 PM
Tfitz
Cars Wanted
22
Mar 24, 2017 05:35 PM
cocopops
Jul 28, 2016 06:29 AM
Ccsob
Cars Wanted
Nov 14, 2014 03:19 PM
