wtb oldsmobile stamped valve covers
Old Jan 5, 2009 | 04:04 PM
olds4life's Avatar
hey olds nation. looking for olds stamped valve covers. send pics and price. thanks wes. wghaskins@yahoo.com
Old Jan 7, 2009 | 05:50 PM
70Post's Avatar
Did you find these?
Old Jan 13, 2009 | 09:06 AM
olds4life's Avatar
no sir, 70post!
Old Jan 13, 2009 | 06:32 PM
70Post's Avatar
I think I have a pair....buried in a box so it may take me some time to find them. Stay tuned. Thanks
Old Jan 14, 2009 | 07:32 AM
olds4life's Avatar
70post are you in Austin TX. if so i plan on moving there in 3 1/2 years. as soon as my son graduates from high school here in st. louis i am outta here. too cold.
Old Jan 14, 2009 | 04:14 PM
70Post's Avatar
Maybe I'll find the valve covers by then and you will save on shipping!
Old Jan 14, 2009 | 05:28 PM
olds4life's Avatar
oh, i see you have jokes today.
Old Jan 14, 2009 | 06:08 PM
Chumley's Avatar
What do you refer to when you say "stamped", ones that say "Oldsmobile" on them, or just stock stamped steel covers?Chumley
Old Jan 14, 2009 | 06:17 PM
70Post's Avatar
People are referring to a valve cover that appeared sometime in the early/mid 70's (maybe '73). These were stamped steel and had "OLDSMOBILE" stamped into the top surface. Raised letters approx 1-1/2 - 2" tall. Pretty cool looking covers....no fancy lettering or anything like that but at least they ID the brand prominently on the top of the cover. They really look good when they have a nice chrome plating job done to them.
Old Jan 14, 2009 | 07:04 PM
redoldsman's Avatar
Proud Viet Nam Veteran
They were used in 73 and 74. They are on ebay pretty often. They usually sell for 50-60 bucks.
Old Jan 15, 2009 | 06:49 AM
olds4life's Avatar
70post, i was just thinking about where i could get them chromed at. would you know of such a place.
Old Jan 15, 2009 | 12:08 PM
70Post's Avatar
To be honest with you the chrome place here in Austin doesn't do real nice work (at least on bumpers) from what I have seen. `
Part of it depends on how slick you want them to look.....and of course that will affect the price of the chrome work. There are a number of places out there, probably a lot closer to you that could easily chrome a pair (check Hemmings or see if someone else pops up on here in your area with a recommendation).
One thing to note...expectations.....I am pretty sure the stamped covers have the oil splash baffles spot welded inside them like the earlier covers. That said, you need to realize that the chrome will not fill or hide the spot weld areas. In other words, whatever the bare surface of a valve cover looks like (dents, spot weld "spots", pitting) is what the chrome will look like.
Sure, someone can try to fill any bad spots with copper, etc but now you are talking TIME and fairly expensive chrome work. This is usually what differentiates the smooth-as-glass chrome work from the other.
If it were me, I would find a set of nice dent free (and hopefully pit-free) covers and get them done. Any minor dings that you can access from the backside of the cover could be "worked out" via pick hammer, dolly, sanding, etc with some time. Remember, the splash shields/baffles on the backside will block your access to the back of any dent that happens to be above the baffle. I've removed the baffles and re-attached them on a couple pair of notched 455 covers I have (to remove a couple small dings)...but again, you are talking more time (cut spot welds, access and remove dings, re-attach baffles via mig or spot welding).
Leave the spot weld "spots" that show up on the outside of the valve covers. It would look exactly like what Olds would have done had they chromed them and put them on motors.
Places like Paul's Chrome (in Hemmings) will typically be VERY EXPENSIVE. You should be able to find a local place that does stuff like this and will do it for a reasonable cost.
Old Jan 16, 2009 | 07:29 AM
olds4life's Avatar
thanks 70post. oh yeah, it's like -5 degrees here in st. louis.
oldspackrat
Apr 14, 2014 08:56 PM
Olds luvr
May 12, 2010 01:24 PM
DennisG.
Jun 14, 2009 07:44 AM
DennisG.
Apr 12, 2009 04:32 PM
crazy'boutOlds
Feb 12, 2009 04:54 AM
