WTB: BOP Engineering Alternator bracket for 455
Old Apr 30, 2019 | 07:08 PM
jpayne_80@hotmail.com's Avatar
I am having a hard time with the unbalanced look of accessories on my 455. I don't plan on ever having A/C and have both alternator and p/s pump on the same side.
Before I buy new I just wanted to see if anyone happened to have the BOP relocating bracket as found here: http://www.bopengineering.com/alternator_kit_b.shtml
Thanks!
Jeff
Old Apr 30, 2019 | 07:48 PM
RetroRanger's Avatar
72 Olds CS
J
IDK if you know but if an olds didnt have AC the alt was put on the passenger side. I think the unbalanced look you comment on is from the alt on the drivers side w no AC comp on the pass side. I woul d contact scott oldspackrat on this site or john 2blu442 and see if they have the pass side alt brakct set up.
Ill see if i have a pic of mine...
Old Apr 30, 2019 | 07:51 PM
72 Olds CS
Not mine but like this
Old Apr 30, 2019 | 09:03 PM
My 455 came from a car with a/c so I have all brackets for that.
Old May 1, 2019 | 03:13 AM
Then it’s just a matter of bolting on the correct water pump, pulleys, and mounting brackets to move the alternator to the passenger side. Pretty easy, try to get everything from the same car, or make sure the pulleys have the the correct code so everything lines up.
Old May 1, 2019 | 06:52 AM
lemoldsnut's Avatar
If I'm not mistaken you do not need to change all the brackets and pulleys. The water pump decides which pulleys you use. I have the passenger side alternator mounting brackets, all 3 pieces. Where are you located also?
Email me direct lemoldsnut@aol.com
Larry
Old May 1, 2019 | 02:40 PM
70cutty's Avatar
Beer Connoisseur
I think I have BOP alternator bracket and spacers somewhere in my garage. I replaced it with a CVF racing bracket. If you are still interested I can look for it this weekend.
CVF has a really nice alternator bracket that's much better quality than BOP.
It's in the picture.
Old May 1, 2019 | 02:49 PM
Whoa! I like that one! Going to look that up!
Old May 1, 2019 | 03:06 PM
Grumbler's Avatar
I have the BOP brackets, it's a simple and clean installation but I'm not crazy about the design. It only uses two long bolts for mounting and they are spaced too close and too high together. I've snapped a bolt three times over the years, thankfully the alternator stays in place, but it's only hanging on with one bolt! Not good. I'm planning on modifying the setup with a brace that connects to one of my no longer used fuel pump bolts. That CVF setup above looks far superior for strength. The BOP sits much lower than the CVF, bolts to the front of the head below the valve cover which I like though
Old Aug 15, 2020 | 11:09 AM
PROJECT BEDLAM's Avatar
Agreed. The B.O.P. 2 bolt setup is useless. I too have snapped grade 8 bolts like pretzels. The CVF alternator bracket for Olds is gonna do the job... From a physics standpoint it makes far better sense, as the stress points are triangulated.
Old Aug 15, 2020 | 01:20 PM
From an engineering standpoint, none of the aftermarket brackets are as good as OEM. Aluminum has only 1/3 the stiffness of steel, and significantly lower fatigue life. More to the point, the factory brackets have been engineered and tested to survive the worst case vibration environments possible for that part. There is no way any aftermarket bracket has had the same level of engineering and testing as the factory brackets. If you want bling, have the stock brackets chromed.
Old Aug 28, 2021 | 11:16 AM
Samadentul's Avatar
I undertook this job but I damage the A/C unit which caused it to leak. There were some brittle o-rings there too, which I replaced at the same time.
Old Sep 22, 2024 | 08:39 AM
KenPresler's Avatar
I know this is a old thread, but if anyone is still set up with notifications. The CVF mounts sits the alternator pretty close to the engine and the grounding screw is a hairs width from it. Is this going to cause an issue with heat and such? We are just building our 455 and there isnt really any drivers side mounts that the interwebs have. Any help or advice would be appreciated. Can get some images if needed but in the picture's on this thread you can see how close it is.
Old Sep 22, 2024 | 09:04 AM
IndianaOlds1971's Avatar
Brackets
I use March Performance to switch to a ribbed belt instead of the V belt, I only have an alternator, the charging stud is higher than the intake so there isn’t any clearance issues or risk of grounding.
John Gregory White
Sep 18, 2019 04:38 PM
ReallyWildStuff
Jul 20, 2017 06:45 PM
CuttyShark
Jul 21, 2015 07:15 AM
1971viking
May 3, 2012 07:08 AM
rallye455
Feb 7, 2011 10:31 AM
