WTB: 69 442 upper antenna spacer
I am looking for the upper antenna spacer for a 69 442. It's the piece that sat in between the gasket and the mast nut on top of the fender. I believe it was chrome plated.
Still looking for this part. The one I got from Lunaboy unfortunately seems to be for a different year Olds. It had a part# of 387726 which as far as I can tell is from a 68 or earlier Olds. The one I am looking for is part#398630. Anyone have this?
Ask dnmfranco. I know he's got at least one & it definitely came from an original 69
sorry bill i thought the one i had sent you was a 69; most likely a 68. I deal mostly with 66 and 70 stuff. if you you want to return for a refund no prob.
sorry I will look around my anteena stuff for that part number. never know i may have it.
Not to hijack, but does anyone have the roughly 2" long black plastic pc. that holds the bottom part of the antenna shaft in place? It has a slit across the top to receive the tabs at the bottom of the antenna before the black plastic nut screws on over it. I think the OD of it should be around .430 and ID about 5/16.
Lunaboy, no big deal. Mine has been missing for quite some time so I couldn't remember what exactly it looked like. The picture you sent me looked correct from what I remembered but obviously there is some slight difference in thickness. I should have asked you to check the part number first. In any case I guess I'll just hang on to it for now. Maybe I can trade it at a swap meet sometime for something I need.
skryla
October 19th, 2011 07:13 PM
Giddy
March 10th, 2009 12:37 PM
