WTB 1970 4 core radiator
Old Mar 8, 2015 | 07:23 AM
cdoering's Avatar
I'm looking for a 4 for radiator for my 1970 442 W30 Convertible automatic with A/C. Let me know if you have one or where I can get one
Chris 314-495-1700
Old Mar 8, 2015 | 12:11 PM
2blu442's Avatar
Chris, if you can come up with the correct code to include in your ad that might help. Are you looking for a rebuilder with good tanks that you can re-core or something to plug and play?
John
Old Mar 8, 2015 | 06:20 PM
cdoering's Avatar
I believe the correct code is IC on the radiator. At this point Ill take whatever I can get
Chris
Old Mar 8, 2015 | 06:21 PM
cdoering's Avatar
I also believe IF & IC are the correct codes
Old Mar 8, 2015 | 07:51 PM
Octania's Avatar
Any of these found on the 88, 98, or Toro? Vista maybe?
Old Mar 8, 2015 | 09:15 PM
2blu442's Avatar
Chris, I have a 1971 flat top wagon with heavy duty cooling. It has the correct 4 row radiator for the 442 and maybe the W30 of that year. So if you have access to a Vista with the 4 row I think it would be worth checking the codes.
John
Old Mar 9, 2015 | 09:30 AM
lunaboy's Avatar
The Rocket Astronomer
i have one of the 70 4 core tanks, IC i belive and a 70 chevelle opposite harrisson tank with the larger 2 inch bottom for 70, not sure on the code, will chk and get you pics if you want to go that way. i was going to use these units for my 70 442 untill i found the correct rad . i think johns' 71 will have the smaller outlet but you can use it with a 71 waterpump.
Old Mar 9, 2015 | 09:36 AM
Don R.'s Avatar
Check this out:
http://www.usradiator.com/catalogsea...oldsmobile+442
Old Mar 9, 2015 | 11:46 AM
cdoering's Avatar
I have the larger outlet on the bottom since I have the 404837 X water pump (2 in bottom). I would be interested in your radiator. Can you send me pics and price?
cdoering1021@yahoo.com
Chris 314-495-1700
Old Mar 9, 2015 | 12:07 PM
cdoering's Avatar
Radiator rebuilder
A rebuilder with good tanks is really waht I'm looking for, easier to ship and cost me less. Unless I can get a full radiaotr at a reasonable cost.
Chris 314-495-1700 (call me with what you have or leads).
Old Mar 10, 2015 | 02:07 PM
lunaboy's Avatar
HAVE THE IF WITH A XF THAT LOOKS THE SAME AS A CI
http://www.ebay.com/itm/331501962982...witem=&vxp=mtr
Old Mar 12, 2015 | 01:55 PM
RocketDevo's Avatar
"IF" and "CH"
I believe the correct radiator for your car is the "ED" rad code tag. Which has the "IF" code on the driver side, and the "CH" code on the passenger side. All 4 core radiators have the "IF" code on the driver side or nothing at all. The passenger side generally signifies the application. It is possible "EC" rad code tag was used but given you have AC which means you had 3:23 gears numerically or lower the "ED" tag type rad was used. I may have one available. By the way the "EC" rad tag tanks are "IF" for the driver side and "CI" for the passenger side. Hope this helps.
Old Mar 12, 2015 | 08:57 PM
orange442's Avatar
This is the radiator that is in both of my 70 W-31's.
Old Mar 13, 2015 | 09:25 PM
cdoering's Avatar
I would take the passenger side. Yes, I do have 3:23 gears in my car.I meant to type CI for the tanks. Let me know if you have it and how much?
Chris 314-495-1700
Old Sep 6, 2015 | 10:59 AM
Stefano's Avatar
Since we are discussing 4 core radiators and codes. What is the going rate for a rebuildable 4 core radiator with IF / CI tanks.
Old Sep 6, 2015 | 12:23 PM
RocketDevo's Avatar
The Last one I had done cost me about $450 I think. That was Canadian dollars so I suspect it would be cheaper in the U.S. The shops get the scrap copper value so that should give you about $35 credit. It they are not passing it on then you can save by removing the tanks, less work for them also, As they just re-soldier a new core to the tanks. I think that would be a better way to go all round as most shops are not going to give you credit for the scrap core value.
Old Sep 9, 2015 | 08:00 AM
jpc647's Avatar
Originally Posted by Don R.
wow those are expensive.
Old Sep 9, 2015 | 08:52 AM
Stefano's Avatar
"Since we are discussing 4 core radiators and codes. What is the going rate for a rebuildable 4 core radiator with IF / CI tanks."
Anyone know what rebuildable core are fetching?
Old Sep 9, 2015 | 09:06 AM
tru-blue 442's Avatar
Old School Olds
I would like to know also. The 70 442 project I have has an IF/CI radiator for it as well.
Old Sep 9, 2015 | 11:00 AM
RocketDevo's Avatar
I have yet to see one come up for sale in a public forum, ebay etc. They are very hard to find, especially with the "EC" rad tag still attached. Finding one in a wrecking yard is not going to happen, and the guy who would have one would need it for his own car or future project. I would say at least $250 for a core. The Parts Place sell's repro's for about $700.
Alex72cutty
Apr 21, 2015 10:30 AM
bronze66f85
Jun 9, 2014 03:50 PM
59Olds98
Aug 14, 2013 09:38 AM
L69
May 19, 2013 11:01 AM
esisson
Jan 14, 2007 04:38 PM
