water pump 68/69 442
Old Oct 10, 2015 | 03:46 PM
servexcell's Avatar
I am looking for a water pump for 68/69 442 400 cubic inch motor
thanks
Bruce
Old Oct 10, 2015 | 03:53 PM
Octania's Avatar
requirements?
Factory casting only?
no imperfections?
date range?
Any old aftermarket unit OK?
AC vs not-AC may matter
Old Oct 10, 2015 | 09:39 PM
servexcell's Avatar
Preferably one from an Oldsmobile , not necessarily date coded. Non AC
Bruce
Old Oct 11, 2015 | 11:28 AM
rcorrigan5's Avatar
Randy C.
Still need more info - does your car have heavy duty cooling? If so, the water pump would be the same as for a car with A/C (GM casting # 400269). Without A/C or heavy duty cooling, the GM casting number is 398681.
Randy C.
Old Oct 12, 2015 | 12:04 AM
Gerald Nickels's Avatar
Yes I have the water pump # 400269
$100 shipped from Calif. to 48 States.
Gerald
Old Oct 20, 2015 | 08:18 PM
servexcell's Avatar
How many styles of water pumps are there? is there different ones for small and big blocks.
I am replacing my 68 350 with a 400 from a 68 442 for a non air car. What pulleys fit with it for water pump and crankshaft , I need those as well.
Old Oct 20, 2015 | 09:12 PM
2blu442's Avatar
It sounds like your 400 engine doesn't have a water pump or pulleys, correct? You can swap over all the pulleys and the water pump from the 350 onto your 400. But you need to keep things together as a set. Once you start mixing and matching pulleys you can get into trouble.
There were three water pump lengths, and if you don't want to re-use the old one on your 350 than remove it and take it to your favorite auto parts store. Make sure the replacement you purchase is the same length, or if you place it flat on the counter the same height. Distance from where the fan attaches to where it fits against the timing chain cover. Then you can use the pulley set. But... if you get a different length water pump then the pulleys will not line up. Some configurations may only be half the width of the belt off, but that's enough to chew up the belt or even throw it going down the highway.
Check out this thread for more details on the water pumps.
https://classicoldsmobile.com/forums...p-lengths.html
John
Old Oct 21, 2015 | 09:49 AM
Octania's Avatar
How many WP configs?
A lot!
3 lengths
x2 inlet nipple OD's
And that's just the main fitment issues.
At least x2 impeller diameters
w/ or w/o heater hose nipple
etc.
Use your 350 engine WP/pulley set and call it done
joesw31
Sep 15, 2022 09:31 AM
ROCKET VAPOR
Sep 19, 2012 08:08 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
brandon reynolds
Mar 5, 2012 03:51 AM
72Ctlss
Jun 23, 2009 03:12 PM
