Wanted: Olds 455 "N" Crank. Cut For 4 Speed Pilot Bearing With Snap Ring
Looking for a 455 N crank. Standard/Standard. Factory cut for a 4 speed pilot bearing with snap ring. Call/Text David at 406-531-6939.
David I dont think I'vre ever seen a pilot bearing retained by a snap ring.
You can always get a crank from a automatic car and have the machine shop bore the end of the crank to accept the pilot bearing.
The blueprinting book from mondello has the dimensions needed for boring.
A little of subject but in the bearing is stuck fill the void behind the bearing with grease. find a wood dowel approx the same size as the hole about two feet long. Stick it in the hole and smack with a hammer. The bearing will pop out
It is the snap ring that is stuck, also the ears are broke on the snap ring, because of the rust. I have it soaking, should able dig it out.
David, let me know if you want any pic's.
Gene
I've been told the pre-1970 were "peened". It looks like the factory took a punch and hit the crank right next to the bearing. Attached is a photo of a 1965 crank. Note the mark near the 6:00 O'clock position. I have used a pilot bushing that fit tightly and didn't do anything to make it stay in place.
John
John
Thanks for all the input.
I am not confident in the machine shop on this. They have never done it before.
I have an auto "N" crank and previously did all the research on the oilite busing. Because I am not finding an N crank from a manual transmission, I am going to let the machine shop give it a go.
I am converting from a TH 350 Auto to manual. Engine is out for rebuild.
Let's say I have the crank drilled for the bushing/pilot bearing, assembly engine and install in car. Then I hold off on doing the 4 speed conversion and put the TH350 Auto back in the car.
??Should I leave the pilot bushing/bearing out and install it when I do the 4 speed conversion??
I know this seems elementary--but my manual trans experience is zero.
Thanks everyone.
Thanks everyone.
I have to say that if a machine shop can't bore a concentric hole in the end of the crank for the pilot bearing, I'd be skeptical of their ability to machine the rest of the crank.
The pilot bearing will have no, er, bearing on the fitment of the torque converter, so you can leave it in or take it out.
sx455raidercelticfan
November 23rd, 2010 05:45 AM
