Wanted NOS 71 350 Cam
Old Dec 6, 2021 | 04:17 AM
I have found that all aftermarket cams are made with blanks and have a smaller base circle and thus don't work with stock non adjustable valve train. I have adjustable pushrods in now and seems ok, but I don't like it. I am looking for a stock factory cam (and lifters if available) for a 71 Cutlass 4 bbl. Thanks, Greg
Old Dec 6, 2021 | 06:28 AM
ROCKETMAN269V's Avatar
An easy fix, rather than tearing your engine down, would be to remove material from the bottom of your rocker arm pedestals.
Old Dec 6, 2021 | 04:26 PM
Very interesting idea, never thought of that. But it would be kinda hard to go back after that was done. Thanks , I'll consider it.
Old Dec 6, 2021 | 04:43 PM
Can you use new push rods that are the correct length to get the same end result? You already have adjustable rods set to the correct length, so just use that length to order new one-piece push rods.
Old Dec 6, 2021 | 05:09 PM
.........But it would be kinda hard to go back after that was done.........
Not at all. A new set of rocker pedestals is cheap.
Old Dec 7, 2021 | 05:22 AM
Oh yeah, that would work.
Old Dec 7, 2021 | 05:35 AM
Well what happened is when I went from a Mondello lumpy cam that I hated (My fault- bad match) to a stock type cam I thought all would be hunky dory with stock puh rods, etc. When I put it all together you could tell it wasn't right, I'll bet there was .040 clearance on the rockers. I had the adjustable pushrods still I had put in when I put in the Mondello cam way back, so I reinstalled them and went thru rotating engine and meticulously set each push rod when on base circle. And it is fine, been driven prolly 10,000 miles that way but I would like it to be as Olds designed. So I thought I would see if I can find a original cam- long shot, I know. I wish I had bought one from GM back in the day... So if I can get one reasonable I will get it and put on shelf and some day change. Thanks for your guys input!
Fonz
Jul 9, 2020 01:53 PM
boondocker
Jul 6, 2020 07:56 PM
costpenn
Oct 1, 2014 01:23 PM
delta254
Jan 29, 2013 07:53 PM
mechanicman81
Mar 3, 2011 07:35 PM
