Wanted 1965 olds 442 frame
Old May 2, 2022 | 02:45 AM
Uncleremus's Avatar
I need a 1965 olds 442 frame. I don't care if it's a from a 66 or 67..not doing a 1000 point car. Just need a good frame
Old May 2, 2022 | 07:05 AM
Rallye469's Avatar
Not sure 66-67 will work....not 100%
Sharing where you are might help.
Old May 2, 2022 | 07:10 AM
Rallye469's Avatar
https://classicoldsmobile.com/forums...i-rear-163999/
Old May 2, 2022 | 08:05 AM
lunaboy's Avatar
The Rocket Astronomer
66 and 67 olds will not fit. 66 buick and pontiac will fit .If its a four speed car and you want it correct. use a manual shift car frame from 64 65 olds
or weld the Z bar bracket in .
Old May 2, 2022 | 12:54 PM
jcdynamic88's Avatar
did you even look here for sale? there is one for $1000 with a posi rr,supposedly a stick car so should be same as 442
Old May 2, 2022 | 02:26 PM
Uncleremus's Avatar
Frame
It's a cutlass frame.looking for 442 specific frame.
Old May 2, 2022 | 02:31 PM
Uncleremus's Avatar
I live in Ohio but I usually drive anywhere to get stuff so location really isn't important to me
Old May 2, 2022 | 04:46 PM
RAG's Avatar
RAG
If it is a manual shift Cutlass car it is a 442 heavy duty frame with correct part number. My 3 on the tree post coupe Cutlass has the 442 frame.
Old May 2, 2022 | 04:47 PM
Uncleremus's Avatar
I totally forgot about that
Old May 2, 2022 | 07:01 PM
which is what i said
Meedeebonz
Feb 25, 2020 06:28 PM
jlrichcreek
Aug 29, 2019 01:10 PM
JATA
Aug 16, 2017 06:01 PM
dbowsher
Aug 30, 2016 07:48 AM
