turbo jetfire motor
if you are putting it in a rat rod you could get away with a regular 215 engine and then find a jetfire turbo setup. it would be easier to find this way. Jim Noel will likely have, or at least find you a turbo setup. jimnoel1@comcast.net , when you find a turbo setup, there will be about a 95% chance it will have to be rebuilt. Jim Noel is the only guy in the world that has the parts and he only sells them as a rebuild service. he is a great guy and does great work. you can come over and look at my Jetfire setup if you want, there is alot to them to make it work correctly. you can also check out http://oldsjetfire.com/ for other info. and also kid442 here has many Jetfire turbo parts.
tailfins
October 24th, 2008 10:35 PM
<sonicguru>
April 2nd, 2007 04:29 AM
