trunk lock cover trim
I need a trunk lock cover trim for my 1973 delta 88, as its originasl one has been damaged by some foolish *** hole where to search it. I tried to enter at usapartssupply site but it appears a written FORBIDDEN, I'm not autorized to enter the site with my server. It is a couple of years I do not visit them site. What happen now
well, the pics are posted, as you can see they try to remove it without result, no, I correct, with the only result to break it with no reasons... piece of craps, useless peaple that wold be erased from the face of the earth
The factory part number of this part is 9835200 .
Oldsmobile called it an "emblem and escouchen"
My research indicates it fits 1971 through 1974 Delta 88 ROYALE models. (not the regular Delta 88)
Hope this helps , good luck with your search.
Charlie
Charlie
USA parts supply does list the emblem , their part number is S12.182W .
Here's a couple of links to their websight;
http://www.usapartssupply.com/upload...75_catalog.pdf
http://www.usapartssupply.com/olds.php
Their phone number is 304-724-6600
If you can't find the correct 1973 piece, and don't mind a little extra flash and color, use one from a 1977-85 Delta Royale. It will have a red background with "Royale" script and looks great on these cars. Attaching points are the same. Drill out the existing rivets and reattach using new pop rivets.
The original piece, as you see, is bad to crack and craze.
goldie442
Aug 21, 2015 11:01 AM
