top front fender trim for 64 starfire
Old Dec 6, 2009 | 10:14 AM
64starfire's Avatar
I have the mirror mounted far forward on the drivers side fender and want to move it back on the door. This leaves holes in the trim. If the passenger side is the same that will work. I'm even considering taking my trim, getting the holes filled, then rechromed. But would prefer a piece already done.
thanks
Greg
Old Dec 6, 2009 | 07:15 PM
rocketraider's Avatar
Oldsdruid
If it's a factory remote mirror car the mirror is supposed to be on the fender instead of the door. The Starfire remote mirror is different from 88/98/J1 because of the crown moulding. BTW the moulding is stainless so you'd have to weld it with stainless rod and then metal finish it, and I expect you'd still be able to see where the holes were.
To do this job correctly you need the front fender and door crown mouldings. The LH & RH do not interchange.
gforcecustoms
Jun 6, 2014 07:03 AM
vistacruiser1971
Sep 29, 2013 01:40 PM
coyote
Jun 16, 2011 04:52 PM
64starfire
Mar 20, 2010 11:55 AM
