rear axle 1964 jetstar 88
I htink you are going to need to find someone parting a '64 J88.
Here's one guy, but it was a bit more than a year ago:
http://forums.aaca.org/f137/1964-old...ts-301295.html
His E-mail is MARTINOS1@COMCAST.NET
Good luck!
Good luck!
Maybe Scott, but I'm still unconvinced.
I'd like to see the dimensions of someones actual '64 J88 shaft compared to the Yukon Gear replacement shaft I linked to. Remember, that is a overlength cut-to-fit shaft, so if the spline end and bearing end dimensons are correct, it should work.
GM Sports Salvage shows a '64 J88 in inventory:
http://gmsportssalvage.com/?q=node/1408
Hi sorry I just read all posts in the other thread and 64 is different than the 65 axles I found
I talked to jetstarman he has 3 complete jetstar rear axles all were removed from 1965 model year. He is not sure if they are the same as 1964 jetstar axles.
If you find they are the same or interchange.
He will sell you an axle
Last edited by 11971four4two; August 2nd, 2012 at 11:21 AM. Reason: 64 - 65 axle interchange
I have no luck, contacted gmsportssalvage and they are willing to sell me the comlete rearend, but it seems now they sold the axle about a month ago... so I still don't have a new axle![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
Is there someone with a Jetstar 88 partscar who can help me??
Thanks again..
Thanks again..
Wim, I'd suggest you pull the good axle shaft then call Yukon gear and ask about this part: http://www.yukongear.com/ProductDeta...px?ProdID=1429
Hopefully they can tell you what to measure (or get a machinist to measure) to determine if their part can be made to work for you. We already know the Jetstar rearend is basically a Pontiac 8.2" 10-bolt. What we need to determine is if the bearing end dimensions are the same as other (F-85/Cutlass) 8.2 10-bolts and if the length of the cut-to-fit axle shaft is sufficient for the Jetstar housing.
What about pulling your old one and take it to a machinist to copy it - Couldn't be more than having an axle shipped overseas.
EDIT: Just read entire thread - copper128, I'm saying get a piece of stock axle with no slots or anything it and have it milled to specs.
Local yard here has 64 Olds 88...see pics...will it work?
Email me direct
GStage1@BuickPerformanceClub.com
Don't know if I can ship the axle US Postal Service or not.
Email me direct
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
Perhaps you could e-mail or call him for a verification. If he should have both axles, if the price is reasonable, and you plan to keep the car, it might be good to buy both.
Thanks for all the tips, I have just send eastwestautoparts a mail for the axle. DVAP seems to have the axles but they won't sell it to me because it must be send overseas.
Several other yards don't have this axle, so far no luck, but I keep looking and I found another local machinery to make the axle, but I must visit them for a price... who knows??
Wim
Wim
![Wink](https://classicoldsmobile.com/forums/images/icons/icon12.gif)
Wim
Wim
this is how it is.... one good and one broken.. and I still don't have a new one... I am now trying local machinery, maybe they can reproduce one for a reasonable price..
It seems that during the restoration a few years ago there has been some welding at the axles because the bearings did'nt fit, that could be the reason why the axle is broken now..
![Angry](https://classicoldsmobile.com/forums/images/icons/icon8.gif)
Tough model to find
big car body with small car engine, brakes, rear end parts
Did I not mention that I have about 50 parts Oldsmobiles?
Believe it or not, that model is among my parts cars. It lost its front suspension and the body is rotted beyond any possible saving. It can donate an axle or 2 to you. I'd suggest buying both of them. Shipping will be expensive but not $1800 expensive. It will take me some time, as I have a real job all day every weekday, and family time also.
So, try an email [NOT a message here] to RocketScience442@hotmail.com with a specific and succinct subject, so it does not get tossed as spam/ scam of which I get about 30 a day... and we'll get you all squared away. We can discuss costs and condition and such privately. A nominal deposit by paypal to "rocketette@hotmail.com" will get the ball rolling. Notice the _different_ paypal eddress.
No Worries.
unless I pull the axles only to find a problem. You get your deposit back if I can't deliver a serviceable part. I keep it if you back out of the deal, for my efforts and expenses.
No Worries.
Perhaps I should get the bearings and ship those as well. A little investigation in the PN manual and Rockauto.com reveals:
BEARING [with retainer]
Gr. 5.855, PN 907682
64-65 J88
67 5200 (Delmont 88 [330 engine big car body, like 64-66 Jetstar 88])
64-69 F85 exc. V.C. or C type (Canadian built with C-Clip Axle)
Cross ref PN's: 391743 , 907484 , 907664 , 907682 ...
National RW507CR $20, 1.378" x 2.747" x 1.306" wide
SKF RW507CR $26
Timken 514003 $23
BOLT, Rear Wheel and Brake Drum to Axle Shaft Flange
Gr. 5.812, PN 1235136
7/16-20 x 1.5 L, 0.472 knurl, 11/32" Shoulder Length
64-66 V.C. & J88;
67-72 F85 exc. Canadian [C type Clip Axle]
Cross Refs: 2070158 , 3230413 , 3775682 , 3775683 , 3775684 , 3784976 , 3819518 , 3851677 , 388125 , 3980406 , 6101861 , 8124584 , 9590259 , 9590271 , 98026 , 980261 , 9934167 , J3230413 , J8124584
Dirt Cheap
SHAFT [LH=RH]
Gr. 5.420, PN 394005
64 J88 [no other applications for this PN]
64-65 J88
SKF RW507CR $26
Timken 514003 $23
64-66 V.C. & J88;
Dirt Cheap
SHAFT [LH=RH]
Bill Piper
Hello Wim, I'm an English guy, now living in Nortern France. I have a 1965 Jetstar 88 convertible. My right side axle has just broken. Can't find one. Did you hear of any 1965 axles when you were searching for yours?
Many thanks, Bill.
Many thanks, Bill.
#32
![Post](https://classicoldsmobile.com/forums/images/icons/icon1.gif)
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
#33
A to Z Auto Parts; Springlake, Michigan; USA; (It is south of Muskegon and west of Grand Rapids; close to Lake Michigan) Telephone: 231-798-2111.
They are open Monday-Friday: 9 A.M. - 5 P.M.; and Saturday: 10 A.M. - 1 P.M. USA Eastern time zone.
Be sure to "shop around". There may be others available.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
Kaline
January 12th, 2013 08:37 PM
