Power window regulator '71 Cutlass
Old Nov 7, 2011 | 05:18 PM
vinny c's Avatar
Cool Power window regulator '71 Cutlass
Hi--I am in need of a drivers side rear quarter power window regulator/with motor for my '71 Cutlass Convertible--It seems impossible to find one--I see that power window conversion kits are available for cars with manual crank--but mine is factory power--don't know if I can use it. Also they sell as a $700.plus set only. I heard that an"A"body Chevelle also uses the same regulator, does anyone have any idea where I can find one. Thanks, Vince
Old Nov 7, 2011 | 05:36 PM
Lady72nRob71's Avatar
I have seen these reproed, but would not trust them. The $700 kits are junk, too. I installed a set and strip a regulator each year, as chinesium is not hard. They were modify-to-fit versions, too.
A clean used one would be best bet.
I will move this to the parts wanted section to help you out...
Old Nov 7, 2011 | 08:35 PM
marxjunk's Avatar
1/4 regs are the same from 68-72..there is no difference in the convert or hardtop in those years..that should open up your search, i see singles all the time on ebay...
Old Nov 7, 2011 | 09:08 PM
66400's Avatar
125.00 good used regulator and motor. Henry
70vista
Dec 3, 2014 03:33 AM
ros6872
May 14, 2014 09:51 AM
197064buickspec
Sep 9, 2013 08:55 PM
bigjaythe1st
Feb 21, 2012 01:44 PM
Lady72nRob71
Dec 14, 2008 04:51 PM
