One 73 to 80 14cc dish Olds 350 standard piston and rod needed
Old Sep 20, 2020 | 09:56 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I believe the 68 to 70 350 2bbl also is the same, as long as it is in useable condition and willing to ship to Canada. PM me with your price and pics. Thanks.
Old Sep 20, 2020 | 02:21 PM
ROCKETMAN269V's Avatar
Rod I have for certain; will have to check on piston. Thanks, Bob.
Old Sep 20, 2020 | 03:44 PM
Old Sep 22, 2020 | 07:37 PM
rocketscientis's Avatar
Pistons /rods /pistons
Have most every type of olds pistons & rods..& tooling to add rods /subtract pistons
took thiis 4655/350 foto other day figurin it would be of use
Hi comp 455 piston & rod & H/C 350 piston without rod
have other pistins available these just handy examples
Old Sep 26, 2020 | 10:31 AM
deaddds's Avatar
If you have a part # I can see if I have it nos.
Old Sep 30, 2020 | 06:45 AM
Good question. I wonder if Joe P on here would know the part number or where to find it. The piston itself may be fine but I won't know till I pull it apart. The rod is not, it is bent. I hydrolocked it using a combustion chamber cleaner which does work to gain compression. I gained 15 psi on the cylinder with the bent rod and 25 on the other. I have done this many times and finally got burnt. Plus heating so the pin can be pressed out, might make the piston unuseable to install again. This is a short term motor, not going to have a perfect balance. The 330 crank I plan on installing was balanced for stock rods with the discontinued 18cc dish Speed Pro forged pistons. It will only see around 5000 rpm. Basically, new rings, bearings and gaskets with the 204/214 to replace the failing custom 214/214 cam Cutlassefi ground for me.
Old Dec 7, 2020 | 07:41 AM
Anyone got one lying around?
Old Dec 7, 2020 | 08:07 AM
Should have quite a few standard pistons
Indeed
Old Dec 7, 2020 | 08:46 AM
deaddds's Avatar
Not sure what is different but part book has code A/B, C or D. Which do you need?
Old Dec 7, 2020 | 09:56 AM
60193W30's Avatar
PM sent
Old Dec 7, 2020 | 04:18 PM
edzolz's Avatar
I made a fixture to press pins out of rods cold. Just wondering if this is making rods or pistons unuseable.
Old Dec 7, 2020 | 05:28 PM
It must be done correctly
piston must be supported where pin comes out
Of piston
Wil post pix of toolin but have to take them ..
Old Dec 7, 2020 | 09:24 PM
edzolz's Avatar
Of piston
That is what my fixture does. It supports the piston while the pin is pressed out of the rod.
Old Dec 11, 2020 | 06:09 AM
What is the procedure to R and R a press fit connecting rod? It is supposed to be red hot or the oil starts burning them pressed out? I may just pick up one reconditioned rod. I am not paying hundreds of dollars for weak factory junk. I may as well spend $1000 and get massively improved modern forged pistons and rods for anything over a couple of hundred dollars. Weight would only need to be removed on the 330 crank, balanced for Speedpro pistons and stock rods. Pretty sure it would clean up at the 4.065" hone to oversize. I have cam bearings, so just install, deck clean and measure journals, pretty sure the .020" and .010" the crank is good, journals are smooth. Anyone have a single piston and rod that is usable? This is only a stop gap engine but I don't want to drive it as a ticking, gutless low oil pressure wonder this next Summer.
Old Dec 13, 2020 | 12:19 PM
Wrist pin is light press fit
May have entire assembly available if that helps
clean parts & warm rod & light oil could help but not required
Air / hydrolic press is nice too
Believe red hot would rehnder rod condition unusable. Lost oil pressure on 425 & even with kill switch , rods & crank were sickening color & would not reuse & they were no where near red hot
Omishjon4@gmail.com
Is best way to communicate
Old Dec 21, 2020 | 02:48 AM
Piston / rod assemblys available
Or sepperate whichever would be most convenient for you
singles , sets , more , less ....
cutlassrichard
Aug 3, 2014 05:47 PM
Olds1971
Feb 20, 2014 09:42 PM
mike's88
May 4, 2012 07:55 PM
xplicit666
May 21, 2009 05:54 PM
Cardinal
Mar 19, 2009 12:55 PM
