oil dipstick tube
Old May 9, 2015 | 08:57 AM
71oldsS's Avatar
oil dipstick tube
Hello all, I am looking for the oil dipstick tube for a 71 350. Thanks
Old May 9, 2015 | 09:48 AM
Oldsragger's Avatar
You can find it new on ebay
Old May 9, 2015 | 11:29 AM
Octania's Avatar
new OEM units are pricey
I have a few used ones
Would need to know the number on your indicator in order to provide a correct part.
Old May 9, 2015 | 05:04 PM
lemoldsnut's Avatar
Greg at supercarsunlimited.com carries them,
Old May 10, 2015 | 08:03 AM
71oldsS's Avatar
the number I found was 401567, hope that is what your looking for.
Old May 10, 2015 | 09:40 AM
Octania's Avatar
Hmmmm
maybe
they tend to get damaged in extraction
yesterday I went to the local yard and pulled two with my slide hammer
Made a movie but alas that ONE tube came loose but refused to allow the bulges past the xst manifold so I had to give up on it. So, one broke off at the block and another came out partway, and the third came out but upon close examination at home, to record where the F and A marks should be, we see that it got cracked at the large bulge.
If you can buy a new one you should do that. Used parts always have imperfections.
I'd have to get like 20 for a good used one, mainly for my time to find, inspect, straighten, verify it suits your indicator, package, get it to the post office.
I did record that for a known matched set, in this case from a 1985 or so RWD 307, measuring down along the line of the tube and indicator, with zero or the "index" being the surface where the block and the lower face of the larger upper tube bulge meet...
F is at 5.8"
A is at 6.6"
A difference of 0.8"
This is a 22511032 common mid-80's V8 indicator mating a tube measuring 12.0" from index surface [bottom of larger bulge] to upper end of tube.
Old May 10, 2015 | 06:01 PM
ferndaleflyer's Avatar
I got 2 new from the Chev dealer----wasn't even $20 for them
Old May 10, 2015 | 06:04 PM
CRUZN 66's Avatar
Olds Fever
I should have a few of these in my NOS stock..... I will check and PM you as soon as I can with availability and pricing....
Old May 10, 2015 | 07:07 PM
Octania's Avatar
in 1975?
Old May 11, 2015 | 05:13 PM
CRUZN 66's Avatar
Olds Fever
The guide tube you need to match up with your indicator (401567) is part number 401568.... I have six or more of these available.... PM me if you haven't found a used one and are interested in NOS....
Old May 11, 2015 | 05:20 PM
Octania's Avatar
PN database says
401568: Guide, Oil Dip Stick, Short, 350
Top of tube to stop collar = 10"
Stop collar to bottom of tube = 5.25"
Total Overall length = 15.25"
and there you go, buy a nice new one from the above providor.
Old May 11, 2015 | 05:25 PM
CRUZN 66's Avatar
Olds Fever
Originally Posted by Octania
PN database says
Thanks for the data backup.... Not trying to step on a sale for you.... Just making an alternative offer... And as you said... NOS/OEM is pricey and there is much to be said for good used OEM parts......
Old May 11, 2015 | 06:33 PM
71oldsS's Avatar
tube
Thanks guys for all the input. I ordered a new one, but I will use these measurements to make sure that it is the right one. Thanks again.
dantecl
Oct 27, 2013 02:50 PM
JSGD1966
Feb 11, 2011 06:37 AM
2blu442
Sep 27, 2010 05:41 AM
Clipperet
Jun 2, 2010 05:11 PM
crazy'boutOlds
Aug 5, 2009 07:55 AM
