Needed for a 70 Cutlass/442
Needed for a 70 Cutlass/442 - Revised
Need the following - all in excellent condition
Black dash pad. No cracks, rips, or waves
Auto Trans bell housing cover.
Ash Tray
Rear Lower boxed control arms - very light pitting OK
Rear upper control arms - very light pitting OK - FOUND
Also, need a front fender patch panel, but not the usual piece. I need from about 1 inch above the marker light cutout down to the bottom of the fender in front of the wheel opening only for the driver's side - any rust free in this area 70-72 will be fine. - FOUND
Thanks.
Ash Tray
Thanks.
Can you post/send a pic of the area that you need for the fender? Also, what trans. for the cover? Tanks, Bob. drolds1@bellsouth.net
I have the front marker light section that I can cut off a fender.
No spare dashpad,but I would suggest finding one from a 70,with the glued chrome bead,or one that never had the chrome bead.That way when you install the new bead,you won't have a million poked holes in it from the barbs.
No spare boxed lowers,but I have uppers,and some nice from upper/lower A-arms,if needed.
Bob, it is for a TH400. It's the plastic one.
Still looking for the auto trans bell housing cover, and rear view mirror glass (not for convertible) already removed from the housing. I will resilver - it just needs to be removed without chips or cracks.
