Need a few mis parts for my 68 442 project
Old Jan 13, 2013 | 08:54 PM
gearheads78's Avatar
car guy
- original air cleaner pie pan (ok if shows some age mine is gone)
- 1 rear 1/4 panel marker bezel (light pitting OK)
- 4-speed back up lamp switch and any mounting or connecting linkage that should go with it
- decent set of black front seat belts ( I need complete bolts, covers, retractors and belts)
- cover / finish trim that mounts under column ( black is first color choice but will consider any color)
- 1 rear lamp socket (all I really need is a ground insert
- 6 screws that hold the door pull / arm rests (2 1/8" ones)
- pin / hardware that connects the master cly to the brake pedal
- LH only door inside release handle (minor pitting ok but not pimpled up like a 15 year old)
- 1 rear ashtray (LH if they are different side to side)
- rear licence plate mount
- standard trans plastic cover and 2 bolts that cover the base of the column at the floor / firewall
- clutch inspection plate
Old Jan 13, 2013 | 09:09 PM
firefighter5174's Avatar
I have some quarter marker bezels, possibly an under steering column cover, rear light socket, and rear license plate bracket. Im home again tuesday and weds and can try to get some pics of I can find everything. May have some of the other screws and stuff but Id have to really dig those all the tubs.
Old Jan 14, 2013 | 04:52 PM
car guy
I will let you know. I might have a deal pending for the stuff you have. Just waiting on a call back.
Old Jan 15, 2013 | 02:00 PM
car guy
easy stuff on the way this is what I still need for now
- decent set of black front seat belts for lap only I still have shoulder belts ( I need complete bolts, covers, retractors and belts)
griz_83ho
Jun 9, 2014 04:01 PM
Dangerbird
Mar 1, 2013 11:13 AM
gearheads78
Jul 28, 2009 07:03 PM
gearheads78
Feb 15, 2009 08:56 PM
