Need 1968 Cutlass/442 Jack Base
Old Sep 17, 2024 | 07:02 AM
RAG's Avatar
RAG
Missing my jack base for my '68 442, send me photos and price to rgreen@Q.com. Thanks.
Old Sep 17, 2024 | 07:10 AM
ROCKETMAN269V's Avatar
I have multiple jacks/parts. What shape is the support tube? Thanks, Bob.
Old Sep 17, 2024 | 02:06 PM
RAG's Avatar
RAG
Here's the photo, zip code is 87047
Old Sep 17, 2024 | 05:13 PM
Thanks; I'll check and let you know.
Old Sep 17, 2024 | 05:48 PM
Paladin31's Avatar
Samplepic
Bob here’s a 68 piece for you to compare
Brett
Old Sep 18, 2024 | 05:08 AM
Thanks Brett!
Old Sep 18, 2024 | 01:45 PM
RAG's Avatar
RAG
Here's photo off a complete set for sale advertised as '68.
Old Sep 19, 2024 | 06:24 AM
newmexguy's Avatar
Jack Base Stands
Numerous bases available, clean southern NM metal. More than this available.
Dave S. zip code 88032
Old Sep 21, 2024 | 09:37 AM
The one that you have pictured is different than the one that Brett posted. There appears to be a "dimple" sticking inward in the middle of the wide side of the opening where the mast fits in and the opposite side looks to have a slight curve to it, as opposed to being straight. Also, the base outer perimeter on the one you show is curved on all four sides, whereas his image shows them as being straight. Here's some of the ones that I found in a box.
Old Sep 21, 2024 | 10:09 AM
70Post's Avatar
You might post a good pic of the other end of the jack shaft since the other end is what is supposed to slip into the trapezoidal base hole.
I also noticed in Bob's pic (showing a bunch of bases) that the LENGTH of the trapezoid hole seems to be different on some....some openings being longer than the others. I'm not talking about the solid "T" profile shafts/bases since those are obvious.
Perhaps a couple of good measurements.....front to back "length" on the shaft end and the two "widths" as well. Might help determine which base style the shaft will fit into (longer trapezoid or shorter trapezoid openings).
Old Sep 21, 2024 | 10:19 AM
Paladin31's Avatar
More pics
I dug out these for better pics & comparison
note the depth of legs to the actual mast socket. And the height of the legs compared to the 72, pierced hole in 68-9 base and the snipped corner
I hope these help
Brett
Old Sep 21, 2024 | 12:06 PM
RAG's Avatar
RAG
Old Sep 21, 2024 | 12:14 PM
OK, Thanks. I'll check.
Old Sep 28, 2024 | 03:07 PM
RAG's Avatar
RAG
Dave the NewMexGuy hooked me up with the perfect one, thanks to everyone.
RALLYE KID
Jul 31, 2024 05:26 PM
RALLYE KID
Jan 31, 2023 05:01 PM
oldspackrat
Oct 1, 2014 03:34 PM
501Paratrooper
Feb 17, 2013 06:15 PM
ctrain22
Oct 3, 2010 02:03 PM
